offroadmediagroup
#1 Posted : Thursday, August 7, 2025 5:57:14 AM(UTC)
offroadmediagroup
The idea that we need to size and position layers with values between zero and one is very user hostile. It requires assumptions and zoom/pan "by eye" which is wholly inconsistent with a designer's vision which can be an actual contract requirement. This can be a huge time waster trying to increment values 0.001 at a time and then throwing it out the window when you zoom to a different value. Other tools like Crop and GT Title actually use pixels as values.
Example: A picture-in-picture window where one input needs to be ##px from the top, ##px from the left, and ####px wide. A second input needs to be ##px from the bottom, ##px from the right, and ###px wide. A logo input needs to be ##px from the bottom, ##px from the left, and ####px wide. This is a very typical PiP layout and use case in many productions.
thanks 1 user thanked offroadmediagroup for this useful post.
Geebs on 8/8/2025(UTC)
mavik
#2 Posted : Friday, August 8, 2025 9:11:03 PM(UTC)
mavik
It has been requested here already
https://forums.vmix.com/...r-overlays-in-multiviews
A bit of information can be extracted here as well
https://forums.vmix.com/...-Overlay-Position-Values
You can take a PS template and position your sources accordingly.
Or, take a look at https://layouts.heretorecord.com/build/ and build your layout there
Or, what I do, is to use a layout xml per client. You can even load dynamically in a single shot. So sources + two shorts for the layout. With dynamic inputs you can even manipulate layers live.
