Joined: 4/24/2023(UTC) Posts: 1  Location: Lubumbashi
Hi all is this Dell laptop can easily run ix 26 for church live stream?
Dell Precision 3520 i7 (7th GEN) Specifications:
Processor: Intel Core i7-7820HQ 2.90GHz Memory: 16GB DDR3 RAM Hard Drive: 512GB Solid State Drive Optical Drive: No Optical Drive Graphics: NVIDIA Quadro M620, 2GB GDDR5 Display: 15.6″ FHD (1920×1080) LED Software: Window 10 Professional (64-Bit) Ports: USB 3.0, HDMI, VGA, RJ-45, USB Type-C Connections: Wifi, Bluetooth, Web Camera Warranty: 6 Month Carry-In Warranty.
Below is the detail of the capture card I used :
Type: HDMI HD Capture Color: Black Grey Input port: HDMI Output port: USB3.0 HDMI input resolution1: 1920*1080@30HZ Max HDMI input resolution2: 1080P/60FPS Video output format: MKV Audio format: LPCM2.0/32-192KHZ/16-24Bit input cable length: AWG 26 HDMI standard cable≤10mm Max working current: 280mA Video output format: YUV/JPEG Support video format: 8/10/12bit Deep color Support audio format: L-PCM Support AWG26 HDMI standard cable: input up to 15 meters Support most acquisition software, such as VLC / OBS / Amcap, etc Support Windows / Android / MacOS Conform to USB Video and UVC standard Conform to USB Audio UAC standard Max working current: 0.4A/5V DC Dimension (L x W x H): 58x23x10 (mm) Without external power supply, compact and portable
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: ELIM  Hi all is this Dell laptop can easily run ix 26 for church live stream?
Type: HDMI HD Capture Color: Black Grey Input port: HDMI Output port: USB3.0 HDMI input resolution1: 1920*1080@30HZ Max HDMI input resolution2: 1080P/60FPS Video output format: MKV Audio format: LPCM2.0/32-192KHZ/16-24Bit input cable length: AWG 26 HDMI standard cable≤10mm Max working current: 280mA Video output format: YUV/JPEG Support video format: 8/10/12bit Deep color Support audio format: L-PCM Support AWG26 HDMI standard cable: input up to 15 meters Support most acquisition software, such as VLC / OBS / Amcap, etc Support Windows / Android / MacOS Conform to USB Video and UVC standard Conform to USB Audio UAC standard Max working current: 0.4A/5V DC Dimension (L x W x H): 58x23x10 (mm) Without external power supply, compact and portable For one camera? That laptop's not going to have a problem BUT your SSD isn't going to allow you to keep many Sunday's worth of recordings. At 1080p 30FPS we need 5 to 12GB per week, mostly in the 8-9 GB range.
