ELIM
#1 Posted : Monday, April 24, 2023 6:59:45 PM(UTC)
ELIM
Congo, The DRC
Hi all is this Dell laptop can easily run ix 26 for church live stream?
Dell Precision 3520 i7 (7th GEN) Specifications:
Processor: Intel Core i7-7820HQ 2.90GHz
Memory: 16GB DDR3 RAM
Hard Drive: 512GB Solid State Drive
Optical Drive: No Optical Drive
Graphics: NVIDIA Quadro M620, 2GB GDDR5
Display: 15.6″ FHD (1920×1080) LED
Software: Window 10 Professional (64-Bit)
Ports: USB 3.0, HDMI, VGA, RJ-45, USB Type-C
Connections: Wifi, Bluetooth, Web Camera
Warranty: 6 Month Carry-In Warranty.
Below is the detail of the capture card I used :
Type: HDMI HD Capture
Color: Black Grey
Input port: HDMI
Output port: USB3.0
HDMI input resolution1: 1920*1080@30HZ Max
HDMI input resolution2: 1080P/60FPS
Video output format: MKV
Audio format: LPCM2.0/32-192KHZ/16-24Bit
input cable length: AWG 26 HDMI standard cable≤10mm
Max working current: 280mA
Video output format: YUV/JPEG
Support video format: 8/10/12bit Deep color
Support audio format: L-PCM
Support AWG26 HDMI standard cable: input up to 15 meters
Support most acquisition software, such as VLC / OBS / Amcap, etc
Support Windows / Android / MacOS
Conform to USB Video and UVC standard
Conform to USB Audio UAC standard
Max working current: 0.4A/5V DC
Dimension (L x W x H): 58x23x10 (mm)
Without external power supply, compact and portable
Roy Sinclair
#2 Posted : Thursday, May 18, 2023 7:22:02 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Color: Black Grey
Input port: HDMI
Output port: USB3.0
For one camera? That laptop's not going to have a problem BUT your SSD isn't going to allow you to keep many Sunday's worth of recordings. At 1080p 30FPS we need 5 to 12GB per week, mostly in the 8-9 GB range.
Similar Topics
Whats best laptop for Vmix (General Discussion)
by Reinaldo 11/22/2019 7:39:18 AM(UTC)
Best laptop for vMix as of 2017 (Hardware Compatibility)
by niemi 2/16/2017 3:28:45 PM(UTC)
new laptop for vMix (Hardware Compatibility)
by geoffreydean 1/17/2016 5:05:51 PM(UTC)
