Reinaldo
#1 Posted : Friday, November 22, 2019 7:39:18 AM(UTC)
Reinaldo
Brazil
Hi all! I need a help!
I want to buy another notebook to my Vmix.
What´s the best option between this two notebooks?
https://www.bhphotovideo...i7_9750h_16gb_512gb.html
or
https://www.bhphotovideo...riton_700_i7_7700hq.html
Thanks!
Reinaldo
#2 Posted : Saturday, November 23, 2019 9:18:44 PM(UTC)
Reinaldo
Brazil
Hi Martin...help me in this decision.
Thanks!
Selinwine
#3 Posted : Tuesday, April 6, 2021 12:44:08 AM(UTC)
Selinwine
Go for the first one, to me that one looks better. But if you want to double check and make sure that you are doing the right choice, then I advise you to do the research and to see if the technical characteristics are compatible with your needs. You won't be able to play video games and to have a clear image, with a poor graphic ram. Does that makes sense to you? If you can't do it by yourself, then google it, there are plenty of blogs with this kind of analysis. This is the website that I found for you: thecursedcrusade.com but I suggest to look for more recommendations. Good luck!
