Hardware Compatibility
Lumens VCA 50P no PTZ control using VISCA over IP
Hi all,
using vMix 4K 25.0.0.34 x64 we succesfully control our Sony PTZ camera from the software.
However, with a Lumens VCA 50 P (without NDI activated, video coming in on SDI) PTZ control does not work. Network is ok, control via browser is fine. Using a Roland hardware video mixer PTZ control works.
Doublecheck with another vMix system also fails.
In vMix, I can connect to the PTZ, but not control the device. Wireshark with a Visca dissector gives an "Unknown command error".
Can somebody confirm this or has a solution/idea?
The vMix website lists the Lumens VCA 50 as compatible.
Thanks,
Christian
Joined: 8/26/2020(UTC) Posts: 4  Location: Velsen / The Netherlands Thanks: 1 times
Hi Christian,
Is your problem solved already?
On the bottum side of the Lumens ptz there is a Camera Address Selectors. That has to be on number 1. And just to be sure, update the firmware to 213 ;-)
Greetings Mano
Hi Mano, thank you for the hint. I did not know that the cam uses an ID system. You might be right, the person renting it to us confirmed the ID setting, so I have to check this out.
Best regards,
Christian
