ckvideo
#1 Posted : Friday, October 28, 2022 12:01:30 AM(UTC)
ckvideo
Germany
Hi all,
using vMix 4K 25.0.0.34 x64 we succesfully control our Sony PTZ camera from the software.
However, with a Lumens VCA 50 P (without NDI activated, video coming in on SDI) PTZ control does not work.
Network is ok, control via browser is fine.
Using a Roland hardware video mixer PTZ control works.
Doublecheck with another vMix system also fails.
In vMix, I can connect to the PTZ, but not control the device. Wireshark with a Visca dissector gives an "Unknown command error".
Can somebody confirm this or has a solution/idea?
The vMix website lists the Lumens VCA 50 as compatible.
Thanks,
Christian
Mano Bakker
#2 Posted : Friday, December 23, 2022 10:10:52 AM(UTC)
Mano Bakker
Netherlands
Hi Christian,
Is your problem solved already?
On the bottum side of the Lumens ptz there is a Camera Address Selectors. That has to be on number 1.
And just to be sure, update the firmware to 213 ;-)
Greetings Mano
ckvideo
#3 Posted : Friday, January 20, 2023 7:51:17 AM(UTC)
ckvideo
Germany
Hi Mano,
thank you for the hint. I did not know that the cam uses an ID system. You might be right, the person renting it to us confirmed the ID setting, so I have to check this out.
Best regards,
Christian
Guest (4)
