Hardware Compatibility
Lumens VCA 50P no PTZ control using VISCA over IP
Joined: 3/21/2022(UTC) Posts: 47  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Hi all,
using vMix 4K 25.0.0.34 x64 we succesfully control our Sony PTZ camera from the software.
However, with a Lumens VCA 50 P (without NDI activated, video coming in on SDI) PTZ control does not work. Network is ok, control via browser is fine. Using a Roland hardware video mixer PTZ control works.
Doublecheck with another vMix system also fails.
In vMix, I can connect to the PTZ, but not control the device. Wireshark with a Visca dissector gives an "Unknown command error".
Can somebody confirm this or has a solution/idea?
The vMix website lists the Lumens VCA 50 as compatible.
Thanks,
Christian
Joined: 8/26/2020(UTC) Posts: 17  Location: Velsen / The Netherlands Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi Christian,
Is your problem solved already?
On the bottum side of the Lumens ptz there is a Camera Address Selectors. That has to be on number 1. And just to be sure, update the firmware to 213 ;-)
Greetings Mano
Hi Mano, thank you for the hint. I did not know that the cam uses an ID system. You might be right, the person renting it to us confirmed the ID setting, so I have to check this out.
Best regards,
Christian
