halfpipe
#1 Posted : Monday, December 19, 2011 8:43:52 PM(UTC)
halfpipe
I'm not sure if this is even a vMix issue but since playing around combining firewire HDV sources and HDMI sources and external sound cards my system won't capture hdv any longer.. Was ok for a few days of experimenting trying to get audio. I thought it might be the firewire port at first but DV still works so the onboard firewire controller seems ok
I cannot capture HDV using hdvsplit anylonger which was without issue for me for years now
Sound familiar to anyone?
thanks
Bruce
melody
#2 Posted : Tuesday, December 20, 2011 6:28:56 AM(UTC)
Rank: Guest
Groups: Guests
hi halfpipe,
try to remember if you installed some codecs pack recently or a new graphic card. i had same problem with hdvsplit previously by updating k-lite codec pack but after select ffmpeg filter the "bug" was fixed.
note: in my case, my motherboard does not work correctly with firewire input (onboard) after large hours. working here with Asus P6T.
regards,
melody
www.espiritosanto.cc
