Joined: 11/11/2011(UTC) Posts: 33  Location: Cold Coast of Nova Scotia Thanks: 2 times
I'm not sure if this is even a vMix issue but since playing around combining firewire HDV sources and HDMI sources and external sound cards my system won't capture hdv any longer.. Was ok for a few days of experimenting trying to get audio. I thought it might be the firewire port at first but DV still works so the onboard firewire controller seems ok I cannot capture HDV using hdvsplit anylonger which was without issue for me for years now Sound familiar to anyone? thanks Bruce
Rank: Guest
Groups: Guests
hi halfpipe, try to remember if you installed some codecs pack recently or a new graphic card. i had same problem with hdvsplit previously by updating k-lite codec pack but after select ffmpeg filter the "bug" was fixed. note: in my case, my motherboard does not work correctly with firewire input (onboard) after large hours. working here with Asus P6T. regards, melody www.espiritosanto.cc
