mikekay
#1 Posted : Saturday, April 24, 2021 8:22:56 AM(UTC)
mikekay
So, I've followed all the instructions to the best of my ability. I have a simple setup, a camera, plugged into the cam link....I get audio in vmix, but no video. I've tried three different cameras. The last one is a Blackmagic Pocket Cam - output is 1080p29 - and everything works in the Elgato capture utility.
What can I try? Is this a know problem with this device - its the first time I tried using it with vmix.
Any help appreciated.
AlanZ
#2 Posted : Saturday, April 24, 2021 11:19:56 AM(UTC)
AlanZ
Try setting the video format to something obscure, and when vMix rejects it, it will show a list of any available resolutions/frame rates/formats.
Then try one of those settings and see if you get video.
AlanZ
#3 Posted : Saturday, April 24, 2021 11:21:26 AM(UTC)
AlanZ
Also, if you haven’t already done it, detach and reattach the Cam Link so it starts fresh.
mikekay
#4 Posted : Saturday, April 24, 2021 9:18:35 PM(UTC)
mikekay
YAY!!!!! - This worked....the last format worked on the list - and you have saved me a TON of extra work, cause this little system will do my event Monday. THANK YOU THANK YOU THANK YOU.
And thanks for all the posts!
AlanZ
#5 Posted : Sunday, April 25, 2021 9:57:05 AM(UTC)
AlanZ
Glad to have helped
