Elgato Cam Link 4K - no video input
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
So, I've followed all the instructions to the best of my ability. I have a simple setup, a camera, plugged into the cam link....I get audio in vmix, but no video. I've tried three different cameras. The last one is a Blackmagic Pocket Cam - output is 1080p29 - and everything works in the Elgato capture utility.
What can I try? Is this a know problem with this device - its the first time I tried using it with vmix.
Any help appreciated.
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
Try setting the video format to something obscure, and when vMix rejects it, it will show a list of any available resolutions/frame rates/formats. Then try one of those settings and see if you get video.
Also, if you haven’t already done it, detach and reattach the Cam Link so it starts fresh.
Originally Posted by: AlanZ  Try setting the video format to something obscure, and when vMix rejects it, it will show a list of any available resolutions/frame rates/formats. Then try one of those settings and see if you get video. YAY!!!!! - This worked....the last format worked on the list - and you have saved me a TON of extra work, cause this little system will do my event Monday. THANK YOU THANK YOU THANK YOU. And thanks for all the posts!
