DLPro
#1 Posted : Tuesday, December 15, 2020 9:14:23 AM(UTC)
DLPro
The show I am currently working on has all 4 Mixes being utilized. Basically I want a script that mimics the "follow" setting, but for turning on/off bus routes. If input one is live in mix 2, then input 2 is automatically routed to bus A, when input one is not live, it is not routed to bus A. Mix 3, bus b, etc. Any tips? I am also happy to pay someone to knock a script together for me, as I don't really have the time to learn it thoroughly at the moment.
#2 Posted : Tuesday, December 15, 2020 9:59:29 AM(UTC)
First one will need to check the API xml for which input is active or not (which might be a mix input)
Regarding mix inputs they can be checked by number (2-4) but their input is not referenced by 1 or 2 but the actual input numbers
So IMO one will need to check on input as usual with additionally if is part of a mix or not to make decisions, in short logic based on input no being active or not
Similar Topics
vmix scripting overlays (General Discussion)
by Kekso_10 10/23/2023 11:31:39 PM(UTC)
Vscheduler 2023-Alternative way for vmix scripting (3rd Party Software and Development)
by nikosman88 4/13/2023 9:00:32 AM(UTC)
Vmix Scripting | How can I get into a variable a DynamicValue (3rd Party Software and Development)
by mateogallegotv 9/14/2022 6:23:19 PM(UTC)
Real Input Cloning through vMix Scripting (General Discussion)
by engelschall 3/14/2022 8:01:09 PM(UTC)
Audio Sidechain Compression through vMix Scripting (General Discussion)
by engelschall 3/14/2022 7:41:25 PM(UTC)
vMix scripting for outputs (General Discussion)
by abo78360 10/8/2021 12:16:57 AM(UTC)
Freelancer Wanted for Vmix Scripting (General Discussion)
by hardayildiz 10/4/2021 8:48:59 PM(UTC)
Vmix Scripting for titles (3rd Party Software and Development)
by noakseyinit 7/8/2021 11:22:16 PM(UTC)
Vmix scripting - can it be used to trigger Titler Live via NDI? (General Discussion)
by Bardiccollege 5/2/2021 11:53:40 PM(UTC)
vMix scripting - How to loop a script? (General Discussion)
by andreypetr 7/14/2019 2:12:35 AM(UTC)
