Hello, I am a beginner in vMix scripting. I found the function (SetOutputx) to set/assign the video input of an output. But I did not found the function to set/asssign the Audio channel of an output. Is there a way to do this ? Many thanks for your help Alain
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
as far as I know there is no such function and...
IMO you should route the audio output settings in the Settings/Output section and not via shortcuts or scripts.
You might loose track of your audio routing when changing it dynamically, which will end in a mess I believe
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
If you send your busses to specific outputs, you can script which bus the audio is routed to which should be the same sort of thing, if I understand your question
 1 user thanked nowski for this useful post.
Originally Posted by: nowski  If you send your busses to specific outputs, you can script which bus the audio is routed to which should be the same sort of thing, if I understand your question Many thanks for this advise. It solves my problem.
