abo78360
#1 Posted : Friday, October 8, 2021 12:16:57 AM(UTC)
abo78360
I am a beginner in vMix scripting.
I found the function (SetOutputx) to set/assign the video input of an output.
But I did not found the function to set/asssign the Audio channel of an output.
Is there a way to do this ?
Many thanks for your help
Alain
Chris Daum
#2 Posted : Monday, December 20, 2021 8:56:16 PM(UTC)
Chris Daum
Germany
as far as I know there is no such function
and...
IMO you should route the audio output settings in the Settings/Output section
and not via shortcuts or scripts.
You might loose track of your audio routing when changing it dynamically,
which will end in a mess I believe
nowski
#3 Posted : Wednesday, December 29, 2021 10:27:55 PM(UTC)
nowski
If you send your busses to specific outputs, you can script which bus the audio is routed to which should be the same sort of thing, if I understand your question
thanks 1 user thanked nowski for this useful post.
abo78360 on 1/31/2022(UTC)
abo78360
#4 Posted : Monday, January 31, 2022 11:59:24 PM(UTC)
abo78360
Many thanks for this advise. It solves my problem.
