The show I am currently working on has all 4 Mixes being utilized. Basically I want a script that mimics the "follow" setting, but for turning on/off bus routes. If input one is live in mix 2, then input 2 is automatically routed to bus A, when input one is not live, it is not routed to bus A. Mix 3, bus b, etc. Any tips? I am also happy to pay someone to knock a script together for me, as I don't really have the time to learn it thoroughly at the moment.
Joined: 12/27/2012(UTC) Posts: 5,505  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
First one will need to check the API xml for which input is active or not (which might be a mix input) Regarding mix inputs they can be checked by number (2-4) but their input is not referenced by 1 or 2 but the actual input numbers So IMO one will need to check on input as usual with additionally if is part of a mix or not to make decisions, in short logic based on input no being active or not
