Mike71
#1 Posted : Wednesday, May 27, 2020 3:55:11 AM(UTC)
Mike71
I have a simple 2 camera setup. A camera has a text/grahpic overlay, I want to cut to the B camera clean with no overlay. How is that possible? I don't want to do it in two steps, fade off the graphic and then cut. This should be straight forward in basic production.
The reverse is true: how to I cut to a camera with a text/graphic overlay, when I use the Cut, the graphic fades on. Is that because there's a time embedded in the overlay channel that forces a fade whenever it's used?
#2 Posted : Wednesday, May 27, 2020 4:36:28 AM(UTC)
Check how to use "triggers" in the manual and on vMix YouTube channel
Kelvin
#3 Posted : Wednesday, May 27, 2020 4:42:01 AM(UTC)
Kelvin
If the overlay always appears on Camera A, you can use the multiview for Camera A to add the overlay.
#4 Posted : Wednesday, May 27, 2020 5:45:33 AM(UTC)
Also several shortcuts can br combined under same key.
Mike71
#5 Posted : Wednesday, May 27, 2020 6:03:52 AM(UTC)
Mike71
Thanks for the reply.
I'm in the middle of trying that good idea. Where to set to trigger; in Settings or in multi-view or in the input. There are many place to check. So the idea is to cut to the multi view instead of the camera. But I might loose a fade to get it on. I'm still playing with getting this idea on.
Mike
Mike71
#6 Posted : Wednesday, May 27, 2020 6:50:15 AM(UTC)
Mike71
Making a multiview is straight forward. I can cut in and out of the multiview. Making a trigger little more challenge.
KnKproductions
#7 Posted : Wednesday, May 27, 2020 9:57:12 AM(UTC)
KnKproductions
vmix cut.JPG (345kb) downloaded 10 time(s).
Reference the picture attached...
On the overlay's triggers, set up "OnOverlayIn" and "OnOverlayOut" to jump between your two cameras.
then setup a shortcut to turn on or off the overlay and that is one way do your overlay induced transition
Jonlima22
#8 Posted : Thursday, May 28, 2020 10:29:30 PM(UTC)
Jonlima22
how do I enable two capture cards simultaneously? I have two Avermedia LGPL, one for each camera. In vmix I can only enable one card or another. never both at the same time
#9 Posted : Thursday, May 28, 2020 11:18:35 PM(UTC)
Hmm so you are not able to have your 2 cameras as input at the same time but asking this in a post regarding a cut between 2 cameras ?
May i suggest asking this in a new post in the hardware section , you will have a better chance of getting a response (as now its buried in another topic )
