Joined: 5/27/2020(UTC) Posts: 5 Location: Northern California
I have a simple 2 camera setup. A camera has a text/grahpic overlay, I want to cut to the B camera clean with no overlay. How is that possible? I don't want to do it in two steps, fade off the graphic and then cut. This should be straight forward in basic production.
The reverse is true: how to I cut to a camera with a text/graphic overlay, when I use the Cut, the graphic fades on. Is that because there's a time embedded in the overlay channel that forces a fade whenever it's used?
Check how to use "triggers" in the manual and on vMix YouTube channel
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
If the overlay always appears on Camera A, you can use the multiview for Camera A to add the overlay.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Also several shortcuts can br combined under same key.
Thanks for the reply. I'm in the middle of trying that good idea. Where to set to trigger; in Settings or in multi-view or in the input. There are many place to check. So the idea is to cut to the multi view instead of the camera. But I might loose a fade to get it on. I'm still playing with getting this idea on.
Mike
Making a multiview is straight forward. I can cut in and out of the multiview. Making a trigger little more challenge.
Joined: 4/6/2019(UTC) Posts: 95  Location: Florida Thanks: 10 times Was thanked: 13 time(s) in 11 post(s)
 vmix cut.JPG (345kb) downloaded 10 time(s).Reference the picture attached... On the overlay's triggers, set up "OnOverlayIn" and "OnOverlayOut" to jump between your two cameras. then setup a shortcut to turn on or off the overlay and that is one way do your overlay induced transition
how do I enable two capture cards simultaneously? I have two Avermedia LGPL, one for each camera. In vmix I can only enable one card or another. never both at the same time
Originally Posted by: Jonlima22  how do I enable two capture cards simultaneously? I have two Avermedia LGPL, one for each camera. In vmix I can only enable one card or another. never both at the same time Hmm so you are not able to have your 2 cameras as input at the same time but asking this in a post regarding a cut between 2 cameras ? May i suggest asking this in a new post in the hardware section , you will have a better chance of getting a response (as now its buried in another topic )
