kason1337
#1 Posted : Thursday, October 3, 2019 1:35:53 AM(UTC)
kason1337
I have recorded 7 sessions (3 cameras each + an ISO of the switch) with vmix's multicorder feature.
25mbps - .mp4 -- I cannot for the life of me get premiere pro or adobe media encoder to be ablet o ingest the footage to put it in a usable state. Proxies crashes media encoder.
pulling in the raw crashes the machine.
I just added an extra SSD R/W 400+ MB/s and 64GB of DDR 4 ram to the machine to see if I was bottlenecking that.
I STILL can't edit this footage.
How can I transcode this stuff to something I can import? how do you work with multicorded footage?
Any help would be great.. :(
danhoff
#2 Posted : Wednesday, July 15, 2020 12:24:12 PM(UTC)
danhoff
You have been a member since:: 7/15/2020(UTC)
Hopefully you've figured this out in the last months, but if you're recording to h.264 in 'fault tolerant' mode, you'll need to 'index' the files after recording, as described here:
https://www.vmix.com/kno...rrectly-in-some-programs
(I wish I'd known this before a whole lot of head scratching!)
deanalepa
#3 Posted : Thursday, November 17, 2022 6:27:52 AM(UTC)
deanalepa
Well, in this situation, you can try to convert all your video files to another format, yes, it may take a lot of time, but in my situation, it helped me fix this kind of issue.
