kason1337
#1 Posted : Thursday, October 3, 2019 1:35:53 AM(UTC)
kason1337
I have recorded 7 sessions (3 cameras each + an ISO of the switch) with vmix's multicorder feature.
25mbps - .mp4 -- I cannot for the life of me get premiere pro or adobe media encoder to be ablet o ingest the footage to put it in a usable state. Proxies crashes media encoder.
pulling in the raw crashes the machine.
I just added an extra SSD R/W 400+ MB/s and 64GB of DDR 4 ram to the machine to see if I was bottlenecking that.
I STILL can't edit this footage.
How can I transcode this stuff to something I can import? how do you work with multicorded footage?
Any help would be great.. :(
danhoff
#2 Posted : Wednesday, July 15, 2020 12:24:12 PM(UTC)
danhoff
Hopefully you've figured this out in the last months, but if you're recording to h.264 in 'fault tolerant' mode, you'll need to 'index' the files after recording, as described here:
https://www.vmix.com/kno...rrectly-in-some-programs
(I wish I'd known this before a whole lot of head scratching!)
deanalepa
#3 Posted : Thursday, November 17, 2022 6:27:52 AM(UTC)
deanalepa
Well, in this situation, you can try to convert all your video files to another format, yes, it may take a lot of time, but in my situation, it helped me fix this kind of issue.
