Can't edit multicorder footage.
Joined: 10/3/2019(UTC) Posts: 1  Location: north richland hills
I have recorded 7 sessions (3 cameras each + an ISO of the switch) with vmix's multicorder feature.
25mbps - .mp4 -- I cannot for the life of me get premiere pro or adobe media encoder to be ablet o ingest the footage to put it in a usable state. Proxies crashes media encoder. pulling in the raw crashes the machine.
I just added an extra SSD R/W 400+ MB/s and 64GB of DDR 4 ram to the machine to see if I was bottlenecking that.
I STILL can't edit this footage.
How can I transcode this stuff to something I can import? how do you work with multicorded footage?
Any help would be great.. :(
Joined: 7/15/2020(UTC) Posts: 15  Thanks: 18 times Was thanked: 3 time(s) in 2 post(s)
Hopefully you've figured this out in the last months, but if you're recording to h.264 in 'fault tolerant' mode, you'll need to 'index' the files after recording, as described here: https://www.vmix.com/kno...rrectly-in-some-programs(I wish I'd known this before a whole lot of head scratching!)
Joined: 11/17/2022(UTC) Posts: 1 Location: USA Austin
Well, in this situation, you can try to convert all your video files to another format, yes, it may take a lot of time, but in my situation, it helped me fix this kind of issue.
