Peter1000
#1 Posted : Wednesday, June 5, 2019 6:19:19 AM(UTC)
Peter1000
Switzerland
Was thanked: 85 time(s) in 65 post(s)
hi coders
changing a text field works fine with SelectedIndex but NOT with Selectedname
this works fine, browser returns "Function completed successfully."
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedIndex=0&Value=GER
this does NOT work, but browser returns also "Function completed successfully."
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home.text&Value=GER
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home&Value=GER
also i have no success with color changing, browser returns "No suitable Function could be found."
http://localhost:8088/API/?Function=SetTextColor&InputName=smallresult&SelectedIndex=0&Value=#FF0000
these are my fields
what i am doing wrong? Thanks for your help
Peter
elgarf
#2 Posted : Wednesday, June 5, 2019 3:24:51 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@Peter1000,
1) Check your InputName. Maybe it should be "smallresult.gtzip"
2) Looks like SelectedName is case-sensitive, use "Home.Text" instead of "Home.text".
3) There is no SetTextColor function, it named SetTextColour.
Peter1000
#3 Posted : Thursday, June 6, 2019 3:32:54 AM(UTC)
Peter1000
Switzerland
no success for SelectedName :-(
this does NOT work, but browser returns "Function completed successfully."
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home.Text&Value=GER
http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=Home.Text&Value=GER
http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=Home&Value=GER
a bit more success with COLOUR instead of color.... BUT
sending this via browser, imediately changes the alpha value to 0, no matter what i send.
this is white with alpha set to 254, FEFFFFFF, after sending this in browser or with HTTP over my client,
Before sending it:
Screen Shot 06-05-19 at 07.27 PM.PNG (108kb) downloaded 2 time(s).
After Sending this: http://localhost:8088/API/?Function=SetTextColour&InputName=smallresult&SelectedIndex=0&Value=#FEFFFFFF
it does not matter which value i send, can also be 0000FF for Blue
Screen Shot 06-05-19 at 07.28 PM.PNG (107kb) downloaded 0 time(s).
here is the smallresult.gtzip (15kb) downloaded 1 time(s). file
#4 Posted : Thursday, June 6, 2019 12:18:56 PM(UTC)
The names need to match exactly, for example HOME is all upper case in your title, so it also needs to be in your commands.
For the colour, the # is a reserved letter in HTTP, so you need to correctly encode it to %23
Here is a handy tool to ensure the URLS are encoded correctly:
https://meyerweb.com/eric/tools/dencoder/
Peter1000
#5 Posted : Friday, June 7, 2019 8:59:32 PM(UTC)
Peter1000
Switzerland
Thanks Martin! Its getting closer :-)
My titles are updating only with Input=2, if they are not in the Preview Window. With InputName=smallresult, they update only, when active in the Preview window
UPDATES TIME, NO MATTER IF IN PREVIEW OR NOT
http://localhost:8088/API/?Function=SetText&Input=2&SelectedName=TIME.Text&Value=1234
UPDATES TIME ONLY IF IN PREVIEW
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=TIME.Text&Value=9999
http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=TIME.Text&Value=9999
Is this a feature or wanted?
Peter
#6 Posted : Saturday, June 8, 2019 10:29:02 PM(UTC)
InputName is not a valid property, it is always Input regardless of using numbers or names.
rickvoskamp
#7 Posted : Saturday, June 8, 2019 11:07:52 PM(UTC)
rickvoskamp
Meaby the problem is the # in the URL? Meaby you can use %23?
Edit: Sorry, i didn’t saw the post of the admin.
Peter1000
#8 Posted : Saturday, June 8, 2019 11:30:02 PM(UTC)
Peter1000
Switzerland
thanks again. works perfect.
sorry
Guest (5)
