Peter1000
#1 Posted : Wednesday, June 5, 2019 6:19:19 AM(UTC)
Peter1000
Switzerland
Was thanked: 82 time(s) in 62 post(s)
hi coders
changing a text field works fine with SelectedIndex but NOT with Selectedname
this works fine, browser returns "Function completed successfully."
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedIndex=0&Value=GER
this does NOT work, but browser returns also "Function completed successfully."
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home.text&Value=GER
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home&Value=GER
also i have no success with color changing, browser returns "No suitable Function could be found."
http://localhost:8088/API/?Function=SetTextColor&InputName=smallresult&SelectedIndex=0&Value=#FF0000
these are my fields
what i am doing wrong? Thanks for your help
Peter
elgarf
#2 Posted : Wednesday, June 5, 2019 3:24:51 PM(UTC)
elgarf
Russian Federation
Was thanked: 229 time(s) in 129 post(s)
@Peter1000,
1) Check your InputName. Maybe it should be "smallresult.gtzip"
2) Looks like SelectedName is case-sensitive, use "Home.Text" instead of "Home.text".
3) There is no SetTextColor function, it named SetTextColour.
Peter1000
#3 Posted : Thursday, June 6, 2019 3:32:54 AM(UTC)
Peter1000
Switzerland
no success for SelectedName :-(
this does NOT work, but browser returns "Function completed successfully."
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home.Text&Value=GER
http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=Home.Text&Value=GER
http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=Home&Value=GER
a bit more success with COLOUR instead of color.... BUT
sending this via browser, imediately changes the alpha value to 0, no matter what i send.
this is white with alpha set to 254, FEFFFFFF, after sending this in browser or with HTTP over my client,
Before sending it:
Screen Shot 06-05-19 at 07.27 PM.PNG (108kb) downloaded 2 time(s).
After Sending this: http://localhost:8088/API/?Function=SetTextColour&InputName=smallresult&SelectedIndex=0&Value=#FEFFFFFF
it does not matter which value i send, can also be 0000FF for Blue
Screen Shot 06-05-19 at 07.28 PM.PNG (107kb) downloaded 0 time(s).
here is the smallresult.gtzip (15kb) downloaded 1 time(s). file
#4 Posted : Thursday, June 6, 2019 12:18:56 PM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
The names need to match exactly, for example HOME is all upper case in your title, so it also needs to be in your commands.
For the colour, the # is a reserved letter in HTTP, so you need to correctly encode it to %23
Here is a handy tool to ensure the URLS are encoded correctly:
https://meyerweb.com/eric/tools/dencoder/
Peter1000
#5 Posted : Friday, June 7, 2019 8:59:32 PM(UTC)
Peter1000
Switzerland
Thanks Martin! Its getting closer :-)
My titles are updating only with Input=2, if they are not in the Preview Window. With InputName=smallresult, they update only, when active in the Preview window
UPDATES TIME, NO MATTER IF IN PREVIEW OR NOT
http://localhost:8088/API/?Function=SetText&Input=2&SelectedName=TIME.Text&Value=1234
UPDATES TIME ONLY IF IN PREVIEW
http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=TIME.Text&Value=9999
http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=TIME.Text&Value=9999
Is this a feature or wanted?
Peter
#6 Posted : Saturday, June 8, 2019 10:29:02 PM(UTC)
InputName is not a valid property, it is always Input regardless of using numbers or names.
rickvoskamp
#7 Posted : Saturday, June 8, 2019 11:07:52 PM(UTC)
rickvoskamp
Meaby the problem is the # in the URL? Meaby you can use %23?
Edit: Sorry, i didn’t saw the post of the admin.
Peter1000
#8 Posted : Saturday, June 8, 2019 11:30:02 PM(UTC)
Peter1000
Switzerland
thanks again. works perfect.
sorry
