Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
hi coders changing a text field works fine with SelectedIndex but NOT with Selectedname this works fine, browser returns "Function completed successfully." http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedIndex=0&Value=GER this does NOT work, but browser returns also "Function completed successfully." http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home.text&Value=GER http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home&Value=GER also i have no success with color changing, browser returns "No suitable Function could be found." http://localhost:8088/API/?Function=SetTextColor&InputName=smallresult&SelectedIndex=0&Value=#FF0000 these are my fields  smallresult.PNG (10kb) downloaded 0 time(s).what i am doing wrong? Thanks for your help Peter
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@Peter1000,
1) Check your InputName. Maybe it should be "smallresult.gtzip" 2) Looks like SelectedName is case-sensitive, use "Home.Text" instead of "Home.text". 3) There is no SetTextColor function, it named SetTextColour.
no success for SelectedName :-( this does NOT work, but browser returns "Function completed successfully." http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home.Text&Value=GER http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=Home&Value=GER http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=Home.Text&Value=GER http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=Home&Value=GER a bit more success with COLOUR instead of color.... BUT sending this via browser, imediately changes the alpha value to 0, no matter what i send. this is white with alpha set to 254, FEFFFFFF, after sending this in browser or with HTTP over my client, Before sending it:  Screen Shot 06-05-19 at 07.27 PM.PNG (108kb) downloaded 2 time(s).After Sending this: http://localhost:8088/API/?Function=SetTextColour&InputName=smallresult&SelectedIndex=0&Value=#FEFFFFFF it does not matter which value i send, can also be 0000FF for Blue  Screen Shot 06-05-19 at 07.28 PM.PNG (107kb) downloaded 0 time(s).here is the  smallresult.gtzip (15kb) downloaded 1 time(s). file
Joined: 1/13/2010(UTC) Posts: 5,354  Location: Gold Coast, Australia Was thanked: 4765 time(s) in 1636 post(s)
Hi, The names need to match exactly, for example HOME is all upper case in your title, so it also needs to be in your commands. For the colour, the # is a reserved letter in HTTP, so you need to correctly encode it to %23 Here is a handy tool to ensure the URLS are encoded correctly: https://meyerweb.com/eric/tools/dencoder/Regards, Martin vMix
Thanks Martin! Its getting closer :-) My titles are updating only with Input=2, if they are not in the Preview Window. With InputName=smallresult, they update only, when active in the Preview window
UPDATES TIME, NO MATTER IF IN PREVIEW OR NOT http://localhost:8088/API/?Function=SetText&Input=2&SelectedName=TIME.Text&Value=1234
UPDATES TIME ONLY IF IN PREVIEW http://localhost:8088/API/?Function=SetText&InputName=smallresult&SelectedName=TIME.Text&Value=9999 http://localhost:8088/API/?Function=SetText&InputName=smallresult.gtzip&SelectedName=TIME.Text&Value=9999
Is this a feature or wanted?
Peter
InputName is not a valid property, it is always Input regardless of using numbers or names.
Meaby the problem is the # in the URL? Meaby you can use %23?
Edit: Sorry, i didn’t saw the post of the admin.
thanks again. works perfect. sorry
