Joined: 12/7/2018(UTC) Posts: 6   Location: São Paulo
Hi, I can use two blackmagic decklink mini recorder 4k for input of two 4k cameras in vmix
My computer is I7 3930k 32 Gb ram 1866 Motherboard Asus P9x79 Pro PNY GTX 680 4Gb
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Yes and No, the blackmagic decklink mini recorder 4k card requires PCI Express x4 mode generation 2, your motherboard has 3 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 1 x PCIe 3.0/2.0 x16 (x8 mode) The issue would be CPU, GPU and Motherboard are old generations, To do 1080/4K video properly, then you will have to upgrade CPU and GPU at minimum. But if your going to upgrade CPU and GPU, then a new mother motherboard, CPU, GPU and RAM would be better option. Originally Posted by: Rodrigo Rey  Hi, I can use two blackmagic decklink mini recorder 4k for input of two 4k cameras in vmix
Thinking of a new computer, which configuration and which capture card you recommend me for 4 cameras 4k, I will not streaming 4k, it would be for the cuts of the virtual cameras ... I will cut in 1080.
Originally Posted by: Rodrigo Rey  Thanks
Thinking of a new computer, which configuration and which capture card you recommend me for 4 cameras 4k, I will not streaming 4k, it would be for the cuts of the virtual cameras ... I will cut in 1080. https://www.vmix.com/pro...x-reference-systems.aspx
Obsidian - 4K Streaming and Recording or the new setup martin has for the Monthly "Fun Time" Live streaming if your budget allows it. Originally Posted by: Rodrigo Rey  Thanks
