Rodrigo Rey
#1 Posted : Friday, January 25, 2019 11:24:15 AM(UTC)
Rodrigo Rey
Brazil
Hi, I can use two blackmagic decklink mini recorder 4k for input of two 4k cameras in vmix
My computer is
I7 3930k
32 Gb ram 1866
Motherboard Asus P9x79 Pro
PNY GTX 680 4Gb
desmar
#2 Posted : Saturday, January 26, 2019 3:08:45 PM(UTC)
desmar
Canada
Yes and No, the blackmagic decklink mini recorder 4k card requires PCI Express x4 mode generation 2,
your motherboard has
3 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8
1 x PCIe 3.0/2.0 x16 (x8 mode)
The issue would be CPU, GPU and Motherboard are old generations, To do 1080/4K video properly, then you will have to upgrade CPU and GPU at minimum.
But if your going to upgrade CPU and GPU, then a new mother motherboard, CPU, GPU and RAM would be better option.
My computer is
I7 3930k
32 Gb ram 1866
PNY GTX 680 4Gb
Rodrigo Rey
#3 Posted : Saturday, January 26, 2019 7:20:54 PM(UTC)
Rodrigo Rey
Brazil
Thinking of a new computer, which configuration and which capture card you recommend me for 4 cameras 4k, I will not streaming 4k, it would be for the cuts of the virtual cameras ... I will cut in 1080.
ask
#4 Posted : Sunday, January 27, 2019 6:48:05 AM(UTC)
ask
Was thanked: 199 time(s) in 181 post(s)
https://www.vmix.com/pro...x-reference-systems.aspx
desmar
#5 Posted : Sunday, January 27, 2019 9:15:56 PM(UTC)
desmar
Canada
Obsidian - 4K Streaming and Recording or the new setup martin has for the Monthly "Fun Time" Live streaming if your budget allows it.
Similar Topics
DeckLink Mini Recorder 4K latency? (Hardware Compatibility)
by jhebbel 3/21/2017 3:42:27 PM(UTC)
DeckLink Mini Recorder 4K - for 1080 or 720 Broadcasts (Hardware Compatibility)
by SHMD 1/24/2017 1:10:09 PM(UTC)
