arastv
#1 Posted : Monday, June 4, 2018 6:43:07 PM(UTC)
arastv
I want to use two usb capture one does not work
thank you for your help
smı grabber device
arastv attached the following image(s):
sinc747
#2 Posted : Tuesday, June 5, 2018 1:53:58 AM(UTC)
sinc747
You may have overloaded the USB controller if you connected two of these. Or these could be the cheap ones where the driver cannot support two at the same time.
Try different ports. Try updating the driver if possible.
- Tom
arastv on 6/5/2018(UTC)
Similar Topics
Out for Program w/o capture card (General Discussion)
by pllcoolj 8/24/2026 6:49:45 AM(UTC)
Blackmagic Decklink capture going offline (Hardware Compatibility)
by gseguin 8/18/2026 6:04:25 AM(UTC)
how to force NDI HX3 capture (NDI)
by h2video.nl 4/8/2026 4:13:39 AM(UTC)
vMix Desktop Capture - from vMix Install vs DL from vmix.com (General Discussion)
by sinc747 2/6/2026 7:16:11 AM(UTC)
NDI Audio Capture only (NDI)
by waxxel 1/14/2026 6:16:25 AM(UTC)
most stable SDI capture card (Hardware Compatibility)
by konstantinos 1/8/2026 9:47:51 AM(UTC)
Vmix 4k with Desktop Capture over Zoom (General Discussion)
by JohnUK 10/8/2025 12:31:50 AM(UTC)
Desktop Capture for vMix (NDI)
by masaru 9/24/2025 5:00:57 PM(UTC)
BRING BACK MAC CAPTURE (NDI)
by ADAMKOHM 9/20/2025 2:18:25 AM(UTC)
Sudden stop of Desktop capture (NDI)
by Covenant 9/8/2025 6:29:57 AM(UTC)
vMixDesktopCapture failed to install on Window 11 (NDI)
by HienBui 8/17/2025 6:30:24 AM(UTC)
Reconnect Desktop Capture automatically (NDI)
by Bruce27 8/6/2025 6:41:52 AM(UTC)
vMix Capture Card Low Frame Rate (General Discussion)
by JohnDoe415 7/4/2025 10:02:42 AM(UTC)
Problems with VMIX and USB and PCI Express capture devices - video delay (Hardware Compatibility)
by dossierp 5/9/2025 3:36:04 AM(UTC)
Desktop Capture from a tablet (General Discussion)
by Gerrit Grobler 4/23/2025 2:07:30 AM(UTC)
VMIX trouble with capture NDI with Alpha channel (NDI)
by ktspn 4/22/2025 6:38:33 PM(UTC)
vMix Desktop Capture Windows rights level? (NDI)
by nethfel 3/9/2025 2:52:17 AM(UTC)
Video capture devices, DirectShow and vMix (Hardware Compatibility)
by Lucilius 3/2/2025 4:27:41 AM(UTC)
HDMI capture dongle disconnects when VMix closed (Hardware Compatibility)
by congoblue 1/14/2025 1:55:13 AM(UTC)
vMix Desktop Capture for Ultra-wide Screens (General Discussion)
by Jamin 12/24/2024 3:57:38 AM(UTC)
Lag while using local desktop capture (General Discussion)
by Chihiro 12/23/2024 7:19:52 PM(UTC)
External HDMI capture card for a PC? (Hardware Compatibility)
by clipads 12/16/2024 3:00:21 AM(UTC)
Help with Capture Card (Hardware Compatibility)
by stamperdog 12/14/2024 7:29:57 AM(UTC)
Recording Screen Capture on OBS - no audio! (General Discussion)
by dunny92 12/13/2024 9:31:23 AM(UTC)
Desktop Capture for NDI 27.0.0.3 Issue (NDI)
by hmimura 12/1/2024 6:38:28 AM(UTC)
vMix Call Local Capture/Record (General Discussion)
by AudioMenu 10/27/2024 6:32:05 AM(UTC)
Possible fix for Screen Sharing Capture issue using vMix Zoom plugin (General Discussion)
by knbPixels 10/26/2024 1:14:05 AM(UTC)
capture vmix port 8099 (3rd Party Software and Development)
by gre2gor 10/16/2024 3:25:04 AM(UTC)
How do I capture my Video Game as a source (General Discussion)
by Patrick N 9/12/2024 5:34:46 PM(UTC)
Problem with image capture via Decklink Quad 2 (Hardware Compatibility)
by svetotehnik 9/12/2024 1:06:12 AM(UTC)
