I want to use two usb capture one does not work thank you for your help smı grabber device arastv attached the following image(s):  s-link-sl-vd017-usb-capture-20-vdeo-edt.jpg (27kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
You may have overloaded the USB controller if you connected two of these. Or these could be the cheap ones where the driver cannot support two at the same time.
Try different ports. Try updating the driver if possible.
- Tom
 1 user thanked sinc747 for this useful post.
