Ads
schneider
#1 Posted : Friday, February 2, 2018 10:20:52 PM(UTC)
schneider
It would be great to be able to set up a playlist of all ads then pick out points after a certain amount thus ensuring you play each ad and maybe can even give stats to the Advertiser.
Currently I just manually pick each add. It would also (maybe it already does) be great if we could click the button for the video that plays it's audio only (with fade values) rather than having to do it via the trigger settings. it's hard when you have 20 or 30 other them.
Similar Topics
Disconnect vMix from Zoom Leads to USB Bus Failures (General Discussion)
by knbPixels 4/18/2025 7:11:09 AM(UTC)
Football (soccer) live stats, squads etc. (General Discussion)
by Footroll 11/30/2024 12:03:27 AM(UTC)
Audeze Maxwell headset (Hardware Compatibility)
by petervk 7/30/2024 5:14:21 PM(UTC)
4 Source Choices for Quadsplit Multiview (Feature Requests)
by MarkNF82 12/16/2023 2:25:44 AM(UTC)
Headsets for commentators generating Noise (General Discussion)
by bar807 8/7/2023 11:18:01 PM(UTC)
Neat little utility syncs vMix with a google spreadsheet (General Discussion)
by DThompson55 8/31/2022 4:32:11 AM(UTC)
USB Headset as audio input (General Discussion)
by ivanh3 2/20/2022 2:05:45 AM(UTC)
Keeping analog headset out active using a USB mixer. (General Discussion)
by Satori84 4/4/2021 4:54:00 AM(UTC)
USB Headset no audio (General Discussion)
by dunk.flight 2/24/2021 9:59:26 AM(UTC)
GPU Overloads with GTX 1650 // UHD 630 (General Discussion)
by jogyth 2/21/2021 6:52:01 PM(UTC)
Suddenly Having GPU and CPU Overloads (Hardware Compatibility)
by twokingsfilms 12/6/2020 3:44:36 PM(UTC)
New to Vmix - using headset? (General Discussion)
by lee6113 11/8/2020 5:41:37 AM(UTC)
SLOW list loads (Feature Requests)
by mitchstein443 11/4/2020 5:56:22 AM(UTC)
Plantronics/Poly headset (Hardware Compatibility)
by Andrew Rix 8/25/2020 4:08:32 AM(UTC)
Monitor master and bus audio in headsets (General Discussion)
by ifeinberg 7/21/2020 12:13:43 PM(UTC)
Multiple image uploads (General Discussion)
by Simsyuk 6/13/2020 8:29:44 PM(UTC)
Bluetooth headset not listed [SOLVED] (General Discussion)
by Simsyuk 5/7/2020 7:27:38 PM(UTC)
Reverb / Echo in my headset. (General Discussion)
by Pastorhjk 4/5/2020 3:38:32 AM(UTC)
USB gaming headsets for live commentators with VmixCall (vMix Call)
by tgdzapa1 2/11/2020 10:39:27 PM(UTC)
Input virtual Ads (graphics) on grass / screen (General Discussion)
by tgdzapa1 11/19/2019 1:56:46 AM(UTC)
Dropped frames in Headset device without having such? (Hardware Compatibility)
by noonsong 9/10/2019 2:26:25 AM(UTC)
Can vMix use a large number of cores and threads? (Systems)
by bain1320 2/8/2019 5:52:08 PM(UTC)
Sports ads ranking riding (GT)
by Sigi 1/22/2019 4:24:20 AM(UTC)
Bluetooth Headset and Mic (When Mic is added, no audio in headset) (Hardware Compatibility)
by mavrick816 3/19/2018 7:04:21 PM(UTC)
Headset slider instead of knob (Feature Requests)
by rowby 3/14/2018 9:34:38 PM(UTC)
2 x Decklink Quads in an Emerald System (Systems)
by antardwip 12/5/2017 12:35:46 AM(UTC)
Threads settings (why 16?) (Hardware Compatibility)
by MarcusJohansson 11/10/2017 9:44:16 AM(UTC)
How to capture usb-headset audio after push-to-tal using NDI (NDI)
by PVP 5/18/2017 11:50:59 AM(UTC)
Loads of CPU cores (General Discussion)
by BloodyIron 5/1/2017 10:34:25 PM(UTC)
Excel Spreadsheets In Data Source (General Discussion)
by JimJacobs 12/27/2016 8:45:25 PM(UTC)
