Bluetooth headset not listed [SOLVED]
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hello, I've installed a new bluetooth headset to my Windows 10 computer and I can hear both the music being played and any recordings I've made using the microphone windows default applications.
Everything is turned on in devices (including privacy etc) and nothing seems to be a problem, however when I launch vMix 23.0.054 x64 and go to input, my bluetooth headset (Yamay M98) isn't listed!
Would anyone have any ideas as to what the issue could (yes I can hear via vMix)? Thanks in advance.
Ignore, found a solution online. I had to edit a reg key, restart and all working now. Here's the link just in case anyone has the same issue:
