How to Input Desktop Audio To Vmix
Hello There,
Is there any option to Input desktop Audio ? Like OBS Open Broadcasting Software has default audio input, and Its Desktop Audio.
Joined: 8/2/2013(UTC) Views messages in topic : 1,113   Location: Fairhope, Alabama USA Thanks: 609 times Was thanked: 207 time(s) in 173 post(s)
vMix does not have this feature. However, you can use Virtual Audio Cables to reroute your speakers to an Audio Input.
- Tom
"Stereo Mix" is not a windows feature and only appears on some systems with Realtek audio hardware.
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
I’ve used a small cable from the headphone jack to the mic input.
I suggest taking a look at VoiceMeeter Banana from VB-Audio. It's a software audio mixer that becomes the default audio device on the computer. It lets you route sounds from the system in/out of vMix in a more flexible manner.
Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: sinc747  vMix does not have this feature. However, you can use Virtual Audio Cables to reroute your speakers to an Audio Input.
- Tom Makes no sense
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: wtmuradiotv  Originally Posted by: sinc747  vMix does not have this feature. However, you can use Virtual Audio Cables to reroute your speakers to an Audio Input.
- Tom Makes no sense Google is your friend - first result searching "Virtual Audio Cable" https://www.vb-audio.com/Cable/index.htmSteve
