How to Input Desktop Audio To Vmix
Hello There,
Is there any option to Input desktop Audio ? Like OBS Open Broadcasting Software has default audio input, and Its Desktop Audio.
vMix does not have this feature. However, you can use Virtual Audio Cables to reroute your speakers to an Audio Input.
- Tom
"Stereo Mix" is not a windows feature and only appears on some systems with Realtek audio hardware.
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
I’ve used a small cable from the headphone jack to the mic input.
I suggest taking a look at VoiceMeeter Banana from VB-Audio. It's a software audio mixer that becomes the default audio device on the computer. It lets you route sounds from the system in/out of vMix in a more flexible manner.
Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: sinc747  vMix does not have this feature. However, you can use Virtual Audio Cables to reroute your speakers to an Audio Input.
- Tom Makes no sense
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: wtmuradiotv  Originally Posted by: sinc747  vMix does not have this feature. However, you can use Virtual Audio Cables to reroute your speakers to an Audio Input.
- Tom Makes no sense Google is your friend - first result searching "Virtual Audio Cable" https://www.vb-audio.com/Cable/index.htmSteve
