james.b.quinn@gmail.com
#1 Posted : Sunday, December 26, 2021 5:28:11 AM(UTC)
Our PTZ Optics NDI 30X Zoom freezes on an infrequent basis. The only fix is to reboot vMix. After the reboot, the camera is back on line.
Does anyone know of a simple reset procedure so we can recover without a reboot?
Does anyone know the root cause?
Under normal operation there does not appear to be anything wrong.
raugert
#2 Posted : Sunday, December 26, 2021 8:03:58 AM(UTC)
raugert
Views messages in topic : 583
Canada
Check if you have the latest firmware installed.. I had an issue where PTZ Optics cameras would go out of sync when using NDI. Doing a firmware update solved the problem. It could be related to you issue ?
#3 Posted : Sunday, December 26, 2021 11:15:01 AM(UTC)
I'll download the latest and see if it fixes the problem. I know we are at least one revision behind. Thanks for your interest
sinc747
#4 Posted : Sunday, December 26, 2021 12:27:23 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
In a pinch, you might also trying "Changing" the Input, which allows you to re-fresh the Input for the camera.
You can find Change on the General tab of your PTZ camera Input.
https://www.vmix.com/help24/InputSettingsGeneral.html
- Tom
james.b.quinn@gmail.com on 12/26/2021(UTC)
#5 Posted : Sunday, December 26, 2021 9:09:25 PM(UTC)
Do you know if doing the change maneuver will disrupt the existing presets. For example, we have multiple settings for the camera which froze, close up, far away, multi-view. Do we lose these if we do the change and select the frozen camera as the "new" camera?
sinc747
#6 Posted : Monday, December 27, 2021 1:46:19 AM(UTC)
sinc747
Good question. Not sure. You may need to test this.
- Tom
#7 Posted : Monday, December 27, 2021 5:12:42 AM(UTC)
I'll give it a test - thanks for the idea
Is there a point to posting the same response multiple times ? (3x so far)
#8 Posted : Monday, December 27, 2021 12:03:59 PM(UTC)
No - just ran the software wrong
