PTZ Optics Camera over NDI freezes
Joined: 11/4/2020(UTC) Posts: 19  Location: Penfield Thanks: 2 times
Our PTZ Optics NDI 30X Zoom freezes on an infrequent basis. The only fix is to reboot vMix. After the reboot, the camera is back on line.
Does anyone know of a simple reset procedure so we can recover without a reboot?
Does anyone know the root cause?
Under normal operation there does not appear to be anything wrong.
Joined: 8/5/2017(UTC) Posts: 577  Location: Manitoba Thanks: 119 times Was thanked: 321 time(s) in 183 post(s)
Check if you have the latest firmware installed.. I had an issue where PTZ Optics cameras would go out of sync when using NDI. Doing a firmware update solved the problem. It could be related to you issue ?
I'll download the latest and see if it fixes the problem. I know we are at least one revision behind. Thanks for your interest
Joined: 8/2/2013(UTC) Posts: 1,090   Location: Fairhope, Alabama USA Thanks: 575 times Was thanked: 202 time(s) in 168 post(s)
 1 user thanked sinc747 for this useful post.
Do you know if doing the change maneuver will disrupt the existing presets. For example, we have multiple settings for the camera which froze, close up, far away, multi-view. Do we lose these if we do the change and select the frozen camera as the "new" camera?
Originally Posted by: james.b.quinn@gmail.com  Do you know if doing the change maneuver will disrupt the existing presets. For example, we have multiple settings for the camera which froze, close up, far away, multi-view. Do we lose these if we do the change and select the frozen camera as the "new" camera? Good question. Not sure. You may need to test this. - Tom
Joined: 12/27/2012(UTC) Posts: 5,459  Location: Belgium Thanks: 312 times Was thanked: 1009 time(s) in 831 post(s)
Originally Posted by: james.b.quinn@gmail.com  I'll give it a test - thanks for the idea Is there a point to posting the same response multiple times ? (3x so far)
No - just ran the software wrong
