7 Pages123>»
#1 Posted : Wednesday, December 22, 2021 1:50:20 PM(UTC)
Was thanked: 4744 time(s) in 1630 post(s)
vMix 25 Preview (25.0.0.10 Beta) is here!
Disclaimer: This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Your feedback is greatly appreciated, please report any bugs or issues in this thread.
Updates: If you purchased vMix prior to 1 January 2020, an additional purchase is required to use this beta or a new Trial may be possible if you have only used the Trial once in the past. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates.
https://account.vmix.com/order/?Upgrade=1
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
https://cdn.vmix.com/download/vmix25preview.exe
New Features and Changes
* LiveLAN
New built in streaming destination, streams to the vMix Web Controller which can be watched from any HTML5 browser on the local network
* More Categories
Up to 16 more categories can now be added with custom colours and labels
* NDI 5
vMix 25 now includes built-in support for the latest NDI 5.
Note, many NDI 5 features are in the free NDI Tools NDI.tv so check that out for more information.
* Preset Bundles and Offline file improvements
Preset bundles can now be saved which include most media assets like videos, images and titles in a single preset file.
Improvements have also been made to existing preset files, if files referenced cannot be found, a single window can be used to locate these prior to opening.
* Added additional virtual sets
* Added support for all the latest AJA capture devices such as Corvid 44 12G and T-Tap Pro. This requires updating the AJA driver to version 16 or higher, available from the AJA web site.
* Added support for custom keyframe frequency in SRT output encoder (defaults 2 seconds).
* Added option to disable NDI preview thumbnails when adding sources, useful for networks with hundreds of sources that may consume excessive bandwidth to generate thumbnails.
* Web Controller and TCP API now restrict access to users on local network only by default.
This can be disabled if needed in Settings
* vMix is now 64bit only. This is due to 32bit only Windows versions no longer being supported.
* New activators: InputAudioAuto, OverlayXAny, BusXSolo, VideoCallSourceOutputX
* New shortcut: OverlayInputXLast
* Various minor bug fixes and improvements
Documentation
https://help.vmix.com/25/
thanks 27 users thanked admin for this useful post.
ask on 12/22/2021(UTC), avsoundguy on 12/22/2021(UTC), monamiga on 12/22/2021(UTC), fluozh on 12/22/2021(UTC), doggy on 12/22/2021(UTC), Zetor1980 on 12/22/2021(UTC), eduardocfs on 12/22/2021(UTC), Peter1000 on 12/23/2021(UTC), RogerBlu on 12/23/2021(UTC), claudeir on 12/23/2021(UTC), mjgraves on 12/23/2021(UTC), NeObr on 12/23/2021(UTC), stigaard on 12/23/2021(UTC), jpetrie on 12/23/2021(UTC), corporatejames on 12/23/2021(UTC), sinc747 on 12/24/2021(UTC), nikosman88 on 12/26/2021(UTC), dasmedienatelier on 12/26/2021(UTC), stevespaw on 12/28/2021(UTC), raugert on 1/3/2022(UTC), clibil on 1/3/2022(UTC), StepBackInTime_TV on 1/4/2022(UTC), Chircanu on 1/5/2022(UTC), mgrayeb on 1/6/2022(UTC), dunk on 2/5/2022(UTC), jcnad on 2/6/2022(UTC), Metroplex Mobile Studio on 2/21/2022(UTC)
fluozh
#2 Posted : Wednesday, December 22, 2021 5:28:23 PM(UTC)
fluozh
Japan
Thank you for releasing preview edition of vMix 25, it looks awesome!
Should I check "UDP Receive Enabled" for receiving NDI5's latest protocol RUDP?
thanks 1 user thanked fluozh for this useful post.
Ryzen6667 on 1/4/2022(UTC)
jpetrie
#3 Posted : Thursday, December 23, 2021 5:53:04 AM(UTC)
jpetrie
I gave the bundle a try, and it did bring a bunch of files in to the zip, but I don't believe it updated the preset to point to this new internal copy of the files. Looks promising though!
EDIT: Can the locate file dialogue do a bit of smart matching in terms of if multiple things are in the same old location and look ahead to see if they are also in the new location?
EDIT 2: Note: Lists do not get triggered by the locate file dialogue and are listed with the path blank.
EDIT 3: When a .vmixZip file is first made, the file references the original location of the assets like a preset would normally do. But after the bundled file is opened in vMix, it unzips itself to a temp directory and rewrites the references to the local copies. However, lists seem to not be included, so that's why my screenshot was blank above (because those are all lists in my preset).
AlanZ
#4 Posted : Thursday, December 23, 2021 12:23:46 PM(UTC)
AlanZ
Two things to report
1) When opening a v24 preset, the dialog box warns that a PPT file has not been found. The file is actually where vMix is reporting it isn't, and when the preset is opened, the input loads correctly.
2) When using LiveLan to display in Chrome on a monitor attached to the same computer as v25, there is a 6 second lag... is this normal for a local client?
#5 Posted : Thursday, December 23, 2021 12:38:44 PM(UTC)
See below, up to 10 seconds as normal:
https://www.vmix.com/help25/LiveLan.html
eduardocfs on 12/23/2021(UTC), sinc747 on 12/24/2021(UTC)
sinc747
#6 Posted : Friday, December 24, 2021 3:16:06 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Possible Bundle Bug
I reported this via email but thought I'd post it here in case others run into it.
error 25.JPG (70kb) downloaded 8 time(s).
I use an existing preset of 73 Inputs and then save it as a Bundle to my Desktop, and exit vMix (and resave the Bundle upon exit). I restart vMix using the vMix Preset Icon on my Desktop for this new Bundle and this error message pops up saying I can't use this Bundle because it's being used elsewhere.
Hmm. No, it is not. Squirms like a bug. Might be a bug. :)
- Tom
EDIT: Yes, I have now learned how to spell Bundle.
xaver
#7 Posted : Friday, December 24, 2021 5:32:24 PM(UTC)
xaver
have you try to save it in an other folder or with an other name?
#8 Posted : Friday, December 24, 2021 5:38:32 PM(UTC)
Tom,
As you have the file saved in dropbox, dropbox is likely locking the file as it syncs, therefore you can't save over it until it has finished again.
Therefore, you should avoid saving directly into a dropbox sync folder to avoid this kind of issue.
thanks 4 users thanked admin for this useful post.
eduardocfs on 12/24/2021(UTC), sinc747 on 12/26/2021(UTC), corporatejames on 12/30/2021(UTC), clibil on 1/3/2022(UTC)
#9 Posted : Saturday, January 1, 2022 10:06:23 PM(UTC)
Strange:
Last added Shortcuts and scripts do not transfer from v24 to v25 for the LAST preset file
double install of vMix , separate folder for v24 and v25.
adding shortcuts and scripts to v24 project , close and open v24 and use last preset , all shortcuts and functions there
close v24 and open v25 , open Last prest , inputs etc looks all fine until one looks at the shortcuts and scripts , recently added not there , all others are
Back to v24, missing shortcuts and scripts are back
Have not noticed this happening between other sequential Versions before
#10 Posted : Saturday, January 1, 2022 10:17:52 PM(UTC)
Like the bundle concept but...
i do not think it should include all general shortcuts and functions but only the preset specific ones.
if i send a bundle to someone i do not want them to have all my other scripts ( especially) & shortcuts except for the ones created and related to for their setup
#11 Posted : Sunday, January 2, 2022 2:21:46 AM(UTC)
doggy,
24 and 25 will use separate main configs once installed, so you won't see any of the global shortcuts / scripts in 24 you added in 25 and vice versa.
This has always been this way between different versions, and is why we recommend only having one version installed on a computer at a time.
As for the bundle, it only includes assets needed by most input types, it does not expand the preset with any settings that are global in nature, so in that respect it should be the same as 24.
eduardocfs on 1/2/2022(UTC), sontoloyo on 1/2/2022(UTC), sinc747 on 1/3/2022(UTC), doggy on 1/3/2022(UTC)
ask
#12 Posted : Monday, January 3, 2022 8:19:23 AM(UTC)
ask
Preset Bundles- I think there may be an issue with the bundle and PowerPoint decks. I have created a bundle, when looking at the zip file all assets seem to be there. However when loading the bundle all non-PowerPoint inputs load but the PowerPoints are reported as not found. Let me know if you want me to send you the bundle.
Cheers
Andrew
#13 Posted : Monday, January 3, 2022 1:53:08 PM(UTC)
yes, there are a few known issues with some inputs in the bundle preset which will be fixed in the next beta update.
eduardocfs on 1/3/2022(UTC)
Salvatore
#14 Posted : Monday, January 3, 2022 9:00:08 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
The new Category Buttons are displayed incorrectly Button_cut.JPG (49kb) downloaded 5 time(s).
usdharris
#15 Posted : Tuesday, January 4, 2022 2:16:35 AM(UTC)
usdharris
Can Version 25 be installed on the same machine as V24 and not cause issues? I want to begin testing it but can't overwrite my existing version since it is used in productions.
Build
#16 Posted : Tuesday, January 4, 2022 3:26:38 AM(UTC)
Build
Lots of cool stuff this update!
Unfortunately, LiveLAN is not useful to me unless I can set the buffer to levels in the milliseconds range. But this might be a limitation of the underlying HLS since it wasn't designed with realtime in mind.
I also love having keyframe intervals as an option in SRT outputs, But it would be more useful to me if I could specify how many frames between the keyframe interval, rather than how many seconds. Or just specify milliseconds. Anything below 1 second (either zero, or trying to do a decimal) results in all SRT encoded outputs failing entirely, which might be a bug.
Looking forward to future iterations on v25 preview! I'll be testing them out.
Ryzen6667
#17 Posted : Tuesday, January 4, 2022 7:51:31 AM(UTC)
Ryzen6667
Netherlands
i would like to know about this as well
#18 Posted : Tuesday, January 4, 2022 12:05:22 PM(UTC)
The UDP options in the vMix NDI Config are not applicable to NDI 5 as NDI 5 supersedes this with RUDP.
eduardocfs on 1/4/2022(UTC), stigaard on 1/4/2022(UTC)
Lospidos
#19 Posted : Tuesday, January 4, 2022 9:28:30 PM(UTC)
Lospidos
Hello all here
Happy new year for everyone here
Just report that here, have error in all choices the same error on first launch
PFBM
#20 Posted : Tuesday, January 4, 2022 9:39:19 PM(UTC)
PFBM
non admin windows user.....
thanks 1 user thanked PFBM for this useful post.
Lospidos on 1/5/2022(UTC)
7 Pages123>»
