52 Pages«<3637383940>»
Attabur
#741 Posted : Saturday, July 3, 2021 11:24:41 PM(UTC)
Attabur
Originally Posted by: raugert Go to Quoted Post
@Attabur
I think you might need to add a line before the Fade command to "Zoom" to the selected preset of the virtual Input. You would use the "Select Index" command for that. (as per page 195 of the vMix Use Guide)
Function SelectIndex
Input Studio_166_A_Wide
Value (use value of 0-3 depending on which preset you want to zoom to)
Function Fade
Input Studio_166_A_Wide (nothing in other fields)
I haven't tested this as I'm not currently at the studio, but something like that should work.
cheers,
Richard
@Richard,
Dear Richard,
Much appreciated your time and prompt reply.
TOPIC - VIRTUAL Set Select option:
I have tried your instruction and multiple ways I have tried. But couldn't get it done.
Maybe it will be too much to ask.... still asking with a high hope.....
If you could kindly create a tutorial on your YouTube Channel/Web or if you could send it here in the vMix forum with some image screenshots... would be really appreciated.
N.B. Could you please add the URL for vMix guide. "You would use the "Select Index" command for that. (as per page 195 of the vMix Use Guide)". I have checked https://www.vmix.com/help23/ and not sure where is page 195. I have also serached for "Select Index" and used it - but it did not work.
Many many thanks in advance.
Kind regards
Attabur
thanks 1 user thanked Attabur for this useful post.
juanplatyo on 7/5/2021(UTC)
lindend
#742 Posted : Sunday, August 1, 2021 3:38:31 PM(UTC)
lindend
Two questions:
1. I have my Web Controller settings inside vMix password protected. The Panel Builder will only connect if there is no password to the vMix Server. Could you add support to supply a userid/password to login?
2. When adding VU Meters, the panel builder is detecting the input sources and active source. However, how can I add a VU Meter for master audio? Don't see outputs listed. Solved this after reading the docs.
Joeboe
#743 Posted : Thursday, August 19, 2021 3:58:41 PM(UTC)
Joeboe
Hi Richard. I am having some issues with Panel Builder ...I can not get my new icons to load, an my templates are no longer opening......I ee loading, but it just freezes and goes no further
raugert
#744 Posted : Friday, August 20, 2021 1:07:35 AM(UTC)
raugert
Canada
Is it only your new templates that won't load or can you open your older templates ? Did this just happen when you added new icons ? (may be a corrupt icon file)
Nothing has changed with the Panel Builder.
Joeboe
#745 Posted : Friday, August 20, 2021 8:18:55 PM(UTC)
Joeboe
The older templates are opening, but not loading any new icons....the templates open with all the layouts correctly....but none of the new icons are loading, and they do not show up in the left column as it did before ..only templates are showing.
raugert
#746 Posted : Saturday, August 21, 2021 4:09:07 AM(UTC)
raugert
Canada
It sounds like you're trying to sync to the iPad version ? If you changed your default "UserIcons folder" in the Desktop Prefs, then the UserIcons may not sync to the iPad. Make sure your icons are in your Documents/vMix Panel Builder/UserIcons directory.
Joeboe
#747 Posted : Saturday, August 21, 2021 12:14:50 PM(UTC)
Joeboe
ok....Thanks...I did not realize that the icons have to remain in the Documents Folder....I moved everything to another drive...
Thanks again
I did return everything to the Default Documents folder, and it is working ...Thanks again....
I haven't seen any new features or updates, have you reached the limit of the app?.....
iperione
#748 Posted : Monday, August 30, 2021 5:21:41 AM(UTC)
iperione
Italy
working on this software since a week.
Tryed to make it communicate with the apple store version app (usine an Ipad mini 2) and even with the android version (using a Lenovo tablet).
No way to connect to the panel builder.
I made all the necessary configurations.
They can connect to vmix (the 2 arrow icon become green), but there is no way to connect to the panel builder to download the templates.
Used 3 different laptop (all with the windows firewall fully disabled).
raugert
#749 Posted : Monday, August 30, 2021 11:06:24 AM(UTC)
raugert
Canada
Make sure that the computer that is running Panel Builder is in fact on the same network and that you entered the correct IP in the "Host Computer" field in the iPad app. Double check that the IP of your computer is the same as what shows up in the "syncing" window when you select "Sync to tablet". Sometimes the IP shown in the "syncing" window reports the wrong IP in certain networks..
Richard
iperione
#750 Posted : Monday, August 30, 2021 3:10:20 PM(UTC)
iperione
Italy
Richard
it was understood!
As I previously wrote the app (Android/Ipad) can see vmix (the arrow icon becomes green) but can't see the panel builder (w/wo "run as admin").
I tryed even using the same pc for vmix and panel builder (same result). Can see vmix but no PB.
I tryed closing vmix, just keeping panel builder on.
PC and IPad were connected to the same network.
I used the same wifi for pcs and ipad.
Then I used a wired connection for vmix/panel builder pc. No way!!
I made all my attempts with my personal home network. Without any firewall.
Just for your info I used
Laptop with Windows 10 LTSC (MSI GF63 with rtx 2060 and intel i7 9750 16GB)
Laptop with Windows 10 Home (OMEN 15 ek1002 with rtx 3070 and intel i7 10870)
Laptop with Windows 7 Home Premium (Alienware r17x R2 witrh intel it Q740 and Radeon HD5800)
Lenovo Android Tablet
Ipad mini 2
all full updated.
I tryed even using fixed IP for laptops!
raugert
#751 Posted : Monday, August 30, 2021 10:38:12 PM(UTC)
raugert
Canada
If you can see vMix, then the app is on the correct network. Check that you entered the correct "Host IP" for syncing files from the computer running Panel Builder. If Panel Builder is on the same PC as vMix ,then you should enter the same IP in the "Host IP" field. If you are using Panel Builder from a different computer, then you would enter that other computer's IP. (see attached image) Don't forget to select "Sync to Tablet" from the file menu when syncing files. (I'm assuming you're probably doing that :) (see attached image)
If these steps still don't help, then there may be something blocking port "1234" on you network.
Host IP.png (1,164kb) downloaded 10 time(s). Sync to tablet.png (1,239kb) downloaded 8 time(s).
iperione
#752 Posted : Tuesday, August 31, 2021 1:16:11 AM(UTC)
iperione
Italy
If these steps still don't help, then there may be something blocking port 1234
At last I think this is the issue.
But I tryed 2 different networks and I've got the same problems.
As soon as possible I will try to check the status of this port...
But I have all the firewall off!!!
Can't figure out what could generate this lock
iperione
#753 Posted : Tuesday, August 31, 2021 6:30:19 AM(UTC)
iperione
Italy
TCP 0.0.0.0:1234 Voyager:0 LISTENING
[vMix Panel Builder.exe]
just checked using "netstat -ab"
strange result is 0.0.0.0 ...... usually it should be 127.0.0.1 or my stayic ip address 192.168.1.27
but according to this result, the problem is located in the app (adroud/ipad) that can't reach the panel builder
Joeboe
#754 Posted : Wednesday, September 1, 2021 11:59:21 PM(UTC)
Joeboe
Something that I had overlooked when I first tried to sync Panel Builder to my iPad....you MUST create the panel Builder on the PC as a tablet Template.....for it to work correctly...I was having issues until I made my templates Tablet Templates....
iperione
#755 Posted : Thursday, September 2, 2021 12:47:03 AM(UTC)
iperione
Italy
yes thankyou, but for now I created just tablet templates for testing purposes (you know)
such as
1 button + 1 fader ... and so on
I won't proceed with a complex project until I'm 100% sure it works
it is the app....
even if I put the correct IP (i push enter after it) and I sync tablet from the panel builder, it is still indicate "no host found"
it's like it is not capable to reach the host on my pc...
JW
#756 Posted : Tuesday, September 14, 2021 4:31:53 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
I've got a problem with the items I have copied from one page to another.
I can't edit them.
And if I perform an 'open last', the new copied items (not saved) are still present.
raugert
#757 Posted : Tuesday, September 14, 2021 7:38:33 AM(UTC)
raugert
Canada
I can't edit them.
Yes, it appears that there is sometimes an issue when copying items from one page to another. I believe this may happen when you click on the canvas of the destinations page, before pasting the objects. I hope to have this fixed in the next version.
If you can send me your template at info@studio793.ca, I will attempt to fix the panel for you. Please include some info as to which items are problematic so that I can delete them for you.
sorry for the trouble,
Richard
thanks 1 user thanked raugert for this useful post.
JW on 9/15/2021(UTC)
Utpc
#758 Posted : Friday, October 1, 2021 2:41:10 AM(UTC)
Utpc
Hi Richard,
I read the user guide and I am aware of the tally able comments. For some reason, the tally light of all my "ColoredButtons" with "Passive" option and all tally able comments is on in my PC. However, the tally light is not on in my iPad except one "ColoredButton" with "Passive" option. Please help me out. I know the tally light of those "ColoredButtons" with all the tally able comments should turn on on my iPad because one button works on my iPad.
Thank you so much.
Rebecca
raugert
#759 Posted : Friday, October 1, 2021 4:41:50 AM(UTC)
raugert
Canada
@Utpc
That is unusual. If the tally lights are working on your PC, then they should also work on the iPad... Can you send me your template file at info@studio793.ca. I can have a look at it and see what might be happening.
thanks,
Richard
Utpc
#760 Posted : Friday, October 1, 2021 4:51:43 AM(UTC)
Utpc
Hi Richard,
Thank you so much for responding to me so promptly. I just sent my file to your email. I am looking forward to your findings. Thank you.
Best regards,
Rebecca
Guest (16)
