sinc747
#1 Posted : Tuesday, February 16, 2021 4:53:06 AM(UTC)
sinc747
I am using the vMix Script Builder from our friends at Studio 793 to build some simple Web Scripts for a project. But I cannot figure out how to address a 2nd PC with a Web Script. Do you know?
TIA!
- Tom
#2 Posted : Tuesday, February 16, 2021 8:41:43 AM(UTC)
sinc747
#3 Posted : Tuesday, February 16, 2021 4:01:47 PM(UTC)
sinc747
Originally Posted by: doggy Go to Quoted Post
Thanks, but not sure what I'm looking for in the forum thread.
- Tom
rudyengels
#4 Posted : Tuesday, February 16, 2021 4:38:56 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
#5 Posted : Tuesday, February 16, 2021 5:17:20 PM(UTC)
- Tom
This Part Tom
Code:
'HTTP
Dim client = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=Some Text")
Dim response = client.GetResponse()
response.Close
replace IP to 2nd pc's
sinc747
#6 Posted : Wednesday, February 17, 2021 3:56:19 AM(UTC)
sinc747
Thanks Rudy & Doggy! That's what I needed.
Now... how can I add a 2nd command to the same script.
So far I have
Dim client = WebRequest.Create("http://192.168.1.25:8088/api/?Function=VideoCallAudioSource&Input=Call 2349873452&Value=BusG")
response.Close
I want to add a 2nd command to the same PC...
Function = VideoCallVideoSource
Input = Call 2349873452
Value = Output2
What is the syntax for a 2nd command in the same script?
Again, thank you!
- Tom
#7 Posted : Wednesday, February 17, 2021 9:18:40 PM(UTC)
Guess something like this might work
Code:
Dim client as WebRequest = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=Some Text")
Dim response As WebResponse = client.GetResponse()
sleep(1000)
client = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=other Text")
response.Close
Peter1000
#8 Posted : Thursday, February 18, 2021 1:05:59 AM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
I was getting errors, not closing the connection after every command. I would suggest to close the connection after every webrequest.
I also believe that you can send a second command faster than waiting a second. Try it out.
Code:
response.Close
sleep(1000)
response.Close
#9 Posted : Thursday, February 18, 2021 1:24:51 AM(UTC)
The sleep time was just a way for the example (setting a text in a title ) for the change to be visible when running the script !
FYI: i was not getting an error omitting the first close , but it of course never hurts
sinc747
#10 Posted : Friday, February 19, 2021 11:01:58 AM(UTC)
sinc747
Awesome Baby!
Thank you.
- Tom
