3rd Party Software and Development
Using a Script to Trigger an API command on a second VMIX [SOLVED]
Joined: 6/16/2015(UTC) Posts: 191   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 50 time(s) in 26 post(s)
I have two VMIX systems - and would like to add some triggers to control a second VMIX system through the API
The reason I would like to do this is because I need to send the same show to different markets, with different opening VT sequences, and title overlays.
I see that I can fire 'scripts' through the VMIX trigger systems.
How would I construct a Script that could do and API call to a second VMIX system.
In other words is there a way I can do a HTTP request from either a web or VB.net script?
Best Regards
Keith
OK got a vb.net script working! only issue is how do I trigger it, as there is no way to set a value (in this case name of script) against SciptStart to specify which script I want to run in the triggers setup for a particular input. i.e OnTransitionIn ScriptStart 'name of script'
Code:Dim webStream As Stream
Dim webResponse = ""
Dim req As HttpWebRequest
Dim res As HttpWebResponse
req = CType(WebRequest.Create("http://10.1.2.56:8088/API/?Function=OverlayInput1In&Input=2"), HttpWebRequest)
res = CType(req.GetResponse(), HttpWebResponse)
webStream = res.GetResponseStream() ' Get Response
Dim webStreamReader As New StreamReader(webStream)
While webStreamReader.Peek >= 0
webResponse = webStreamReader.ReadToEnd()
End While
Script is a little bit longer than it needs to be, but added in some stuff so you can actually read the response and error trap if you want. Keith
 2 users thanked kgoodyer for this useful post.
Joined: 11/17/2020(UTC) Posts: 4  Location: Villach Thanks: 4 times
Hi, i use this script to control the PTZ API of my AXIS Camera. e.g.: http://192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2But there are some functions, than can only be set with logging in at the Camera. Just writing http:// USER:PASSWORT@192.168.4.111/axis-cgi/com/ptz.cgi?rpan=-2 does not work. So is there a possibility to send user and password with a HttpWebRequest?Best, Thomas
