Stupid Question - Web Scripting - How do you address a remote PC?
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
I am using the vMix Script Builder from our friends at Studio 793 to build some simple Web Scripts for a project. But I cannot figure out how to address a 2nd PC with a Web Script. Do you know?
TIA!
- Tom
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: doggy  Thanks, but not sure what I'm looking for in the forum thread. - Tom
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Originally Posted by: sinc747  Originally Posted by: doggy  Thanks, but not sure what I'm looking for in the forum thread. - Tom This Part Tom Code:'HTTP
Dim client = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=Some Text")
Dim response = client.GetResponse()
response.Close
replace IP to 2nd pc's
Thanks Rudy & Doggy! That's what I needed.
Now... how can I add a 2nd command to the same script.
So far I have
Dim client = WebRequest.Create("http://192.168.1.25:8088/api/?Function=VideoCallAudioSource&Input=Call 2349873452&Value=BusG") Dim response = client.GetResponse() response.Close
I want to add a 2nd command to the same PC... Function = VideoCallVideoSource Input = Call 2349873452 Value = Output2
What is the syntax for a 2nd command in the same script?
Again, thank you!
- Tom
Originally Posted by: sinc747  Now... how can I add a 2nd command to the same script.
Guess something like this might work Code:Dim client as WebRequest = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=Some Text")
Dim response As WebResponse = client.GetResponse()
sleep(1000)
client = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=other Text")
response.Close
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 87 time(s) in 67 post(s)
I was getting errors, not closing the connection after every command. I would suggest to close the connection after every webrequest. I also believe that you can send a second command faster than waiting a second. Try it out. Code:Dim client as WebRequest = WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 0- The Classic Blue.gtzip&SelectedName=Headline.Text&Value=Some Text")
response.Close
sleep(1000)
response.Close
Originally Posted by: Peter1000  I was getting errors, not closing the connection after every command. I would suggest to close the connection after every webrequest. I also believe that you can send a second command faster than waiting a second. Try it out.
The sleep time was just a way for the example (setting a text in a title ) for the change to be visible when running the script ! FYI: i was not getting an error omitting the first close , but it of course never hurts
Awesome Baby!
Thank you.
- Tom
