13 Pages«<45678>»
Rinsky
#101 Posted : Wednesday, December 16, 2020 2:12:27 AM(UTC)
Rinsky
Originally Posted by: RichDanby Go to Quoted Post
I've just spent 40 mins trying to get it to do it again and failing! Hopefully Rinsky has more luck.
I was able to recreate the error, but it only worked once. It seems pretty random.
I deleted the files and then pressed the cancel button and not the ok button.
Maybe it has also something to do with recording while there are no inputs connected or something like this.
pm
#102 Posted : Wednesday, December 16, 2020 3:16:52 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
I had this issue today too. But as you, Rinsky, I was not able to reproduce. After 30mins I gave up.
- In my case, it has nothing to do with an old 23 profile. The profile was built from scratch with version 24 and with new empty session folder.
- One of my last actions I've done was changing the camera assignment of the replay input.
- Seconds later I pressed "Delete All".
But as I said, no luck to reproduce. Other sources of error most be involved.
RichDanby
#103 Posted : Wednesday, December 16, 2020 3:21:14 AM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
When running in separate channel mode the selected event list is saved for each channel but the list of events isn't updated when switching between the channels.
To recreate
Select Channel B
Select Event List 2
Select Channel A - Result: Event list 1 becomes selected
Start Replay Recording
Mark an In and Out - Result: Event added to Event List 1
Select Channel B - Result: Tab for Event List 2 becomes highlighted but events for Event List 1 still show.
ask
#104 Posted : Wednesday, December 16, 2020 12:50:28 PM(UTC)
ask
Has the NDI Configure Source option been removed from the right click menu? Cheers, Andrew.
#105 Posted : Wednesday, December 16, 2020 1:13:47 PM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
Some NDI menu options aren't available if you are using FEIM.
FEIM is only for emergency use only, in cases where you have a specific problematic NDI source, it should not be used in general due to the performance hit.
ask on 12/16/2020(UTC), eduardocfs on 12/18/2020(UTC)
ask
#106 Posted : Wednesday, December 16, 2020 1:17:02 PM(UTC)
ask
Thanks Martin. That makes sense. I turned it off and restarted and all is well. Happy to report that this update seems stable. I haven't been able to find any issues and I have been using it solidly for the last couple of days.
#107 Posted : Wednesday, December 16, 2020 3:34:22 PM(UTC)
Originally Posted by: pm Go to Quoted Post
I'm not shure if it's a bug in 24 or not. But at least the behaviour in 23 is different.
Steps to reproduce:
- Default settings of a newly added instant replay input
- Instant replay recording enabled
- Live mode enabled
- Selected "Show live sources in Replay A and B when in Live mode"
- Create an event by pressing -5
- Select the event in list
- Press "Play Events"
V23
-> Replay A goes to program
-> Selected event is played
V24
- A/B is in sync mode
-> Live feed of the in A selected camera is played
-> But, progress bar of the selected event is shown
Thanks for checking.
Thanks, we will get this fixed.
#108 Posted : Wednesday, December 16, 2020 3:54:27 PM(UTC)
To recreate
Select Channel B
Select Event List 2
roverradio
#109 Posted : Friday, December 18, 2020 1:57:02 PM(UTC)
roverradio
When clicking gear icon on an input, then Copy From to copy settings from another input, you can copy the Layers settings from the other input, but it doesn't copy over the border settings for each layer (they're blank).
Oaktown
#110 Posted : Sunday, December 20, 2020 3:27:25 AM(UTC)
Oaktown
I've been using 24 in production without any issues for the past few weeks but I've noticed that when I made changes in the settings that require vMix to restart there is a 50/50 chance it will hang and I will need to use the task manager to quit vMix. When I restart vMix, it starts on a blank deck and I have to reload last or a saved show to resume my work.
Is it something anyone else has experienced?
Frédéric
#111 Posted : Sunday, December 20, 2020 4:08:03 AM(UTC)
I noticed pretty much the same behaviour as Oaktown.
As him any changes in the settings which requires a restart will cause vMix to hang.
But I also encountered a few issues on closing the software even when no settings were changed. I'm trying to see what causes this or how to reproduce the issue. Not sure... So far I feel like it happens nearly everytime a vMixCall was used. Yesterday it also happened with a single input (a local desktop capture) that was recorded for over 2 hours.
This happened maybe 15 times in the last 3 weeks since I installed v24 (in trial mode) on a new computer. I checked windows event viewer but nothing seems to be reported.
Hardware for this test machine is:
- Asus Prime Z270-A with i7 7700K
- 8 Go DDR4
- GTX 1660 Super
- 3 SSDs
- Power 650 Watts
Windows 10 Pro 64 bits with 20H2
Apart from this problem on closing, everything I tested seems to work OK, except the DynamicInput input/value via the API. Even did a 8 vMixCall production last week, went fine except I had to kill vMix at the end.
Rinsky
#112 Posted : Sunday, December 20, 2020 8:07:35 AM(UTC)
Rinsky
It's not really a bug, but I preferred it like it was in the old replay system that when you copied one event to another event list, it would always be sorted by time.
But now it will just put it in the order you copy it to the event list.
There is an option that let's it sort by timestamp, but it doesn't work.
Oaktown
#113 Posted : Monday, December 21, 2020 12:07:08 AM(UTC)
Oaktown
Not sure if it's a bug or something on my end, but it seems that the feature to "show blank frame when call disconnects" seem to reset itself when I save and reopen the show.
Frédéric
#114 Posted : Monday, December 21, 2020 4:03:30 PM(UTC)
vMix 24.0.0.40 beta released
https://cdn.vmix.com/download/vmix24preview.exe
New Features
* Input numbers now displayed in Audio Mixer as well
* Hovering over input or mixer titles will display full input name.
* Layer templates now include previews showing cropping and border settings.
* Layer templates can be imported/exported as separate files for use on other systems
* Merge effect will now disable borders if they do not match during merge.
This is due to borders not being dynamically resizable/changeable for performance reasons.
* Dynamic values and inputs now shown in API XML
Bug Fixes
* Border settings now correctly copied when using Copy From and Templates
* Fixed Replay issue where black levels for Output1-4 did not display correctly in live preview
* Fixed Replay issue where changing between A and B would not update events list if different tabs are used on each
* Copy To/Move To menu/shortcuts fixed to sort the new item as expected. Copy/Paste will still use the past position as before without sorting.
* Fix for dynamic inputs not working from API Functions
* Dynamic1-4 now selectable as inputs in Triggers
* Fix for replay issue in rare occasions when deleting all data (hopefully! we haven't been able to replicate the issue but added more error checking just in case)
* Live previews in Replay were still displaying by mistake when playing events.
thanks 12 users thanked admin for this useful post.
stigaard on 12/21/2020(UTC), doggy on 12/21/2020(UTC), rudyengels on 12/21/2020(UTC), elvis55 on 12/21/2020(UTC), DWAM on 12/21/2020(UTC), RichDanby on 12/21/2020(UTC), sinc747 on 12/22/2020(UTC), eduardocfs on 12/22/2020(UTC), stevespaw on 12/22/2020(UTC), ask on 12/22/2020(UTC), raugert on 12/22/2020(UTC), Poppa Monsoon on 12/24/2020(UTC)
#115 Posted : Monday, December 21, 2020 4:33:13 PM(UTC)
Update Available notification will now show for beta updates where the beta is already installed.
vMix Update will also now work to update betas.
If the beta is not already installed, the latest non-beta release will still be shown.
avsoundguy on 12/22/2020(UTC), eduardocfs on 12/22/2020(UTC)
Waxmann
#116 Posted : Monday, December 21, 2020 10:19:14 PM(UTC)
Waxmann
Germany
Hi, i cant install 24.0.0.40 , I get a message that there is a serious virus. defender immediately deletes the files.
elvis55
#117 Posted : Monday, December 21, 2020 11:03:07 PM(UTC)
elvis55
Switzerland
#118 Posted : Monday, December 21, 2020 11:10:04 PM(UTC)
Update your Windows Defender, as I can confirm the file is clean as per the latest Windows Defender definitions.
elvis55
#119 Posted : Monday, December 21, 2020 11:29:06 PM(UTC)
elvis55
Switzerland
I can confirm. I've never had problems with vMix, not even with 24.0.0.40
sam602
#120 Posted : Tuesday, December 22, 2020 12:02:19 PM(UTC)
sam602
Trinidad And Tobago
I also got this after installing 24.0.040
Guest (12)
13 Pages«<45678>»
