vMix 24 Early Preview Released!
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Hi Martin,
This behaviour has not changed in 24. Only virtual sets in the following folder are shown in the list: C:\Program Files (x86)\vMix\VirtualSets And thumbnails will only be shown where a thumbnail.jpg file is preset in the folder.
Martin vMix
Dear Martin
Quick (but urgent) question How do I move Audio Matrix Presets from one machine to another? Are they stored as separate files or in the settings?
I just upgraded my whole system to fix a bunch of hardware issues, and I got the settings and main vmix presets over...
Only thing left is those pesky audio matrix presets - I have about 40 of them
To clarify I cant just replace the whole settings file as I have tons of other stuff in the settings, so I need a way to export and import the Audio Matrix Presets - thanks!
Please help Grateful as always BenC
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
There is an error/bug in IR when...
Pressing the Play Button, then Transitioning In with a Stinger, clicking on other events, because I want to play multiple different events and decide by click on them to go to the next one...everything works fine until this point.
But when I want to transition out again with a Stinger to a live camera feed for example, then the IR event jumps back to the first selected event and doesn't stay on the last event, which makes it an ugly cut inside the stinger transition.
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
I moved to the new 24 update (24.0.0.46) and I get this error every time.
"One or more Camera Recordings has failed. Check the log for details"
Error Code: Replay Tick
I then created a new replay session and then hit record same result.
I tried this using multiple inputs, a single input and even using an output as an input. Same error message each time.
This is by design, you cannot manually change events between a transition in and out. Build a separate events list for exactly what you want to play.
Originally Posted by: Radiotvpat1982  I moved to the new 24 update (24.0.0.46) and I get this error every time. Please send a support report from Settings -> About in vMix and email us your registration key so we can investigate further. https://www.vmix.com/contact-us.aspx
I think I actually solved my issue but found another.
I added a new SSD when I moved to 24. I set my replay to record on that new SSD.
I ended up closing vmix, restarting the machine, deleting the replay folder, and reformating the drive. Works fine now......
I did however notice that when I installed 24 it removed 23 from my PC which I thought was not supposed to be the case. I had an event coming up so reinstalled 23 and wont hop back over to testing 24 again till some time next week.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
I noticed a glitch in replay playback. I don't know how long this has been a problem, and I don't know where to download previous beta versions to see when the problem started. When playing back either multiple replay events, or a single event with multiple camera angles checked, there will be a glitch when fading between the angles. This only happens when playback speed is less than 100%. It never happens at 100% speed, and doesn't always happen when < 100% speed. I've replicated this issue on two different computers. Some particulars: - I'm running at 1080p 29.97 FPS.
- The replay session settings are also 1080p 29.97 FPS, at HQ quality.
- Happens with as few as 2 cameras enabled in the replay session settings.
- AMD Ryzen 9 3900X 3.8 GHz 12-Core CPU, and NVIDIA Quadro M4000 GPU.
- Also happens on an AMD Ryzen 4950G APU with integrated graphics, no discrete GPU.
-- Kevin
vMix 24.0.0.47 beta releasedhttps://cdn.vmix.com/download/vmix24preview.exe* NDI updated to 4.6.2 to fix issue where NDI outputs may cause vMix to hang on exit. * VST3 improved compatibility for plugins sharing UI across multiple input plugin instances. * Fixed replay glitch that could occur during transitions at slow motion speeds. We hope to release this as the public 24 version Real Soon Now(TM) once we have confirmation that the above issues are fixed for all users. Regards, Martin vMix
 10 users thanked admin for this useful post.
Thanks Martin! This fixed the replay bug form me. Also rans some VST Plugins on a show this morning with no issues.
-TJ-
Wow that was quick! I reported the replay glitch yesterday, and today there's a fix! Awesome!
-- Kevin
Joined: 6/18/2020(UTC) Posts: 26   Location: Manila Thanks: 57 times Was thanked: 3 time(s) in 3 post(s)
Wow! ready for release. So exciting
Joined: 5/8/2019(UTC) Posts: 37  Location: Port of Spain Thanks: 14 times Was thanked: 1 time(s) in 1 post(s)
Martin I still did not get the "update available" link in v.46 to goto v.47. I had to do a full download and install.
I got the notification at the bottom of the vMix window. Wonder why yours is different.
Cannot say...but I did not see it.. and did the manual update.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
I got the notification as well
I got the "Update Available" Notification, maybe to your setting
You have been a member since:: 4/1/2017(UTC) Posts: 14   Location: Leuven-Belgium Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
vMix crashed 4x today, after installing .47.
Once when reopening the same project. 3x times when removing VST from the master audio.
Same scenario each time. When clicking remove, vMix no longer responding for +/- 5 seconds and than just closes. No message what so ever.
Can I send you some logs or so?
There appears to be a VST3 issue introduced as a result of a previous fix! Will get that fixed...
 4 users thanked admin for this useful post.
