13 Pages«<111213
#241 Posted : Monday, February 22, 2021 12:30:35 PM(UTC)
Was thanked: 4745 time(s) in 1631 post(s)
Hi Martin,
This behaviour has not changed in 24.
Only virtual sets in the following folder are shown in the list:
C:\Program Files (x86)\vMix\VirtualSets
And thumbnails will only be shown where a thumbnail.jpg file is preset in the folder.
BenC
#242 Posted : Tuesday, February 23, 2021 8:35:30 AM(UTC)
BenC
South Africa
Dear Martin
Quick (but urgent) question
How do I move Audio Matrix Presets from one machine to another?
Are they stored as separate files or in the settings?
I just upgraded my whole system to fix a bunch of hardware issues, and I got the settings and main vmix presets over...
Only thing left is those pesky audio matrix presets - I have about 40 of them
To clarify I cant just replace the whole settings file as I have tons of other stuff in the settings, so I need a way to export and import the Audio Matrix Presets - thanks!
Please help
Grateful as always
BenC
Rinsky
#243 Posted : Wednesday, February 24, 2021 10:49:53 PM(UTC)
Rinsky
There is an error/bug in IR when...
Pressing the Play Button, then Transitioning In with a Stinger, clicking on other events, because I want to play multiple different events and decide by click on them to go to the next one...everything works fine until this point.
But when I want to transition out again with a Stinger to a live camera feed for example, then the IR event jumps back to the first selected event and doesn't stay on the last event, which makes it an ugly cut inside the stinger transition.
Radiotvpat1982
#244 Posted : Thursday, February 25, 2021 1:48:15 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
I moved to the new 24 update (24.0.0.46) and I get this error every time.
"One or more Camera Recordings has failed. Check the log for details"
Error Code: Replay Tick
I then created a new replay session and then hit record same result.
I tried this using multiple inputs, a single input and even using an output as an input. Same error message each time.
#245 Posted : Thursday, February 25, 2021 12:43:07 PM(UTC)
This is by design, you cannot manually change events between a transition in and out. Build a separate events list for exactly what you want to play.
#246 Posted : Thursday, February 25, 2021 12:43:45 PM(UTC)
Please send a support report from Settings -> About in vMix and email us your registration key so we can investigate further.
https://www.vmix.com/contact-us.aspx
Radiotvpat1982
#247 Posted : Saturday, February 27, 2021 12:59:05 AM(UTC)
Radiotvpat1982
I think I actually solved my issue but found another.
I added a new SSD when I moved to 24. I set my replay to record on that new SSD.
I ended up closing vmix, restarting the machine, deleting the replay folder, and reformating the drive. Works fine now......
I did however notice that when I installed 24 it removed 23 from my PC which I thought was not supposed to be the case. I had an event coming up so reinstalled 23 and wont hop back over to testing 24 again till some time next week.
kross
#248 Posted : Thursday, March 4, 2021 11:19:43 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
I noticed a glitch in replay playback. I don't know how long this has been a problem, and I don't know where to download previous beta versions to see when the problem started.
When playing back either multiple replay events, or a single event with multiple camera angles checked, there will be a glitch when fading between the angles. This only happens when playback speed is less than 100%. It never happens at 100% speed, and doesn't always happen when < 100% speed.
I've replicated this issue on two different computers.
Some particulars:
  • I'm running at 1080p 29.97 FPS.
  • The replay session settings are also 1080p 29.97 FPS, at HQ quality.
  • Happens with as few as 2 cameras enabled in the replay session settings.
  • AMD Ryzen 9 3900X 3.8 GHz 12-Core CPU, and NVIDIA Quadro M4000 GPU.
  • Also happens on an AMD Ryzen 4950G APU with integrated graphics, no discrete GPU.
-- Kevin
#249 Posted : Thursday, March 4, 2021 4:24:46 PM(UTC)
vMix 24.0.0.47 beta released
https://cdn.vmix.com/download/vmix24preview.exe
* NDI updated to 4.6.2 to fix issue where NDI outputs may cause vMix to hang on exit.
* VST3 improved compatibility for plugins sharing UI across multiple input plugin instances.
* Fixed replay glitch that could occur during transitions at slow motion speeds.
We hope to release this as the public 24 version Real Soon Now(TM) once we have confirmation that the above issues are fixed for all users.
thanks 10 users thanked admin for this useful post.
MickeyMJJ on 3/4/2021(UTC), imintmedia on 3/4/2021(UTC), Roi on 3/5/2021(UTC), DWAM on 3/5/2021(UTC), STADIORADIO on 3/5/2021(UTC), stigaard on 3/6/2021(UTC), avsoundguy on 3/6/2021(UTC), ask on 3/7/2021(UTC), raugert on 3/7/2021(UTC), NeObr on 3/8/2021(UTC)
imintmedia
#250 Posted : Thursday, March 4, 2021 11:57:26 PM(UTC)
imintmedia
Thanks Martin!
This fixed the replay bug form me.
Also rans some VST Plugins on a show this morning with no issues.
-TJ-
kross
#251 Posted : Friday, March 5, 2021 2:38:50 AM(UTC)
kross
Wow that was quick! I reported the replay glitch yesterday, and today there's a fix! Awesome!
-- Kevin
Roi
#252 Posted : Friday, March 5, 2021 12:33:58 PM(UTC)
Roi
Philippines
Wow! ready for release. So exciting
sam602
#253 Posted : Saturday, March 6, 2021 5:11:18 AM(UTC)
sam602
Trinidad And Tobago
I still did not get the "update available" link in v.46 to goto v.47. I had to do a full download and install.
kross
#254 Posted : Saturday, March 6, 2021 6:18:54 AM(UTC)
kross
I got the notification at the bottom of the vMix window. Wonder why yours is different.
sam602
#255 Posted : Saturday, March 6, 2021 7:13:15 AM(UTC)
sam602
Trinidad And Tobago
Cannot say...but I did not see it.. and did the manual update.
avsoundguy
#256 Posted: : Saturday, March 6, 2021 11:18:46 AM(UTC)
avsoundguy
I got the notification as well
Roi
#257 Posted : Saturday, March 6, 2021 10:55:03 PM(UTC)
Roi
Philippines
I got the "Update Available" Notification, maybe to your setting
IrvinCee
#258 Posted : Monday, March 8, 2021 8:18:06 AM(UTC)
IrvinCee
vMix crashed 4x today, after installing .47.
Once when reopening the same project.
3x times when removing VST from the master audio.
Same scenario each time.
When clicking remove, vMix no longer responding for +/- 5 seconds and than just closes.
No message what so ever.
Can I send you some logs or so?
#259 Posted : Monday, March 8, 2021 12:20:44 PM(UTC)
There appears to be a VST3 issue introduced as a result of a previous fix! Will get that fixed...
doggy on 3/8/2021(UTC), IrvinCee on 3/8/2021(UTC)
#260 Posted : Monday, March 8, 2021 2:39:52 PM(UTC)
vMix 24.0.0.48 beta released
* Fix for VST3 plugin issue in .47
This is also the first public release of vMix 24, so all further discussion should proceed to that announcement thread.
https://forums.vmix.com/.../t26309-vMix-24-Released
thanks 4 users thanked admin for this useful post.
stigaard on 3/8/2021(UTC), IrvinCee on 3/8/2021(UTC), doggy on 3/8/2021(UTC), Roi on 3/9/2021(UTC)
Guest (10)
13 Pages«<111213
