52 Pages«<2728293031>»
PeterH
#561 Posted : Thursday, December 3, 2020 8:18:31 AM(UTC)
PeterH
Hi Richard,
- is it possible to load a default panel when starting the android app? Something like "open last template on start up" in the windows version?
- is it possible to change the display size to greater vaules than 1024 x 768 ? I have tried to set the values in prefs, but no effect
raugert
#562 Posted : Thursday, December 3, 2020 1:52:57 PM(UTC)
raugert
Canada
Currently there is no "Open Last on Startup" for Tablets. I'll look into it for the next release..
Yes ou can change default Desktop or Tablet size in the preferences to greater than 1024x748. Note: You can only adjust the size of the current open template type (eg: if a Tablet template is open then you can only adjust the Tablet size, if a Desktop is open then you can only adjust the Desktop size).
cheers,
Richard
raugert
#563 Posted : Friday, December 4, 2020 3:07:05 AM(UTC)
raugert
Canada
** Panel Builder users need your support **
The Panel Builder app uses the information in the vMix API XML to 'tally' the buttons. Unfortunately, some information is not yet available in the API, therefore some commands cannot change the state or "tally" the buttons.
Quite often, feature requests for improvements to the vMix API are unsupported by users at large. These request are important to 3rd party app developpers that are working for you (Most of the time for Free). Typically, the vMix admins look at the number of +1 replies supporting the request before considering action.. If you don't support it, it may not be considered.
If you are a Panel Builder user and want to support some new features requested by other users, please add your (+1) to the following threads.
https://forums.vmix.com/...ioSource--to-the-API-XML
https://forums.vmix.com/...ctivator-for-SOLO-of-BUS
https://forums.vmix.com/...Auto-activator#post85838
https://forums.vmix.com/...in-the-API-XML#post85961
thanks,
Richard
thanks 3 users thanked raugert for this useful post.
Narcogen on 12/4/2020(UTC), talrmd on 12/9/2020(UTC), Frank Broughton on 1/22/2023(UTC)
Marvin
#564 Posted : Friday, December 4, 2020 12:56:02 PM(UTC)
Marvin
Hi, is anyone know how to save the icons into the templates, I import the icons into the user, but after save, close and open the template, the icons disappear, how can I keep then in the user box, thanks
raugert
#565 Posted : Friday, December 4, 2020 4:42:57 PM(UTC)
raugert
Canada
There may be a bug when importing UserIcons using the "+" button.
Try importing your icons by using the "Tools >Import UserIcons" feature. You should do this before you open or create a panel. The icons should then remain the next time you launch the app.
Richard
thanks 1 user thanked raugert for this useful post.
Marvin on 12/4/2020(UTC)
Marvin
#566 Posted : Friday, December 4, 2020 11:34:09 PM(UTC)
Marvin
Thanks so much Richard
Marvin
#567 Posted : Saturday, December 5, 2020 12:28:30 PM(UTC)
Marvin
Hi Richard, I star a new templates, import new icons, but still, not show up after safe the template, a message came the icon are missing, but this time if I click on the + the icon show up, i try difference icon, but still no working, what else can i do? or it may be a bug with the panel building. thanks for the help
raugert
#568 Posted : Saturday, December 5, 2020 12:51:57 PM(UTC)
raugert
Canada
@Marvin
Can you email me your template at info@studio793.ca I'll have a look at it and try to see what's happening.
thanks
Richard
Marvin
#569 Posted : Saturday, December 5, 2020 1:15:07 PM(UTC)
Marvin
Sure, I just did. thanks so much
Studiorove
#570 Posted : Tuesday, December 8, 2020 10:52:01 PM(UTC)
Studiorove
Ireland
Love the software, so trying to implement it in my workflow. Is there a way to take the 'input' value from the button and put it into a script? I want to use the same script triggered by a button, but each button would allow me to execute that script, but using a different input.
Script:
Function=VideoCallAudioSource&Input=Jonathan&Value=BusA
Function=AudioBusOff&Input=Jonathan&Value=Master
Function=AudioBusOn&Input=Jonathan&Value=A
Function=SoloOn&Input=Jonathan
I want to replace 'Jonathan' with the value programed into the button.
Thanks.
raugert
#571 Posted : Wednesday, December 9, 2020 12:49:19 PM(UTC)
raugert
Canada
@Studiorove
Each button must contain it's own script. Here's a quick way of adding a common scripts into buttons:
1. Program a common script in the first button and then 'export' it.
2. Then 'import' the script into another button and only modify the Input values.
It could save you some time :)
cheers,
Richard
#572 Posted : Saturday, December 12, 2020 12:30:28 AM(UTC)
Hi Richard !
Just updated to the latest build in order to experiment with the Dynamic Inputs and Values. First thank you for having them already available in Panel Builder.
2 insights :
- it seems you implemented the SetDynamicInputX feature to use the Value field.
However the manual says (sorry it was updated last night only so you obviously couldn't know already !)
"Set the Value of this shortcut to a Number or Name of the input you wish to assign."
I tried to select my desired input in the input dropdown and it did not work.
Then I tried with the Value field and it worked, either when using the input name, number or GUID
Wouldn't it make more sense to be able to use the input dropdown to select the input by name (and setting it by GUID) for use with the SetDynamicInputX function ?
- Martin found a bug in the API when trying to use the DynamicInputX function so we have to wait a bit before using it.
However I expected to see DynInput1 to 4 in VMPB input dropdown.
Do you plan to add them or is this by design knowing that we can type in what we want in the dropdown ?
Merci d'avance et bien à toi !
Guillaume
#573 Posted : Saturday, December 12, 2020 12:40:20 AM(UTC)
One more thing... The manual now states
Activators are supported for Dynamic Inputs. If an activator is assigned to Input 5 and Event InputDynamic1 then that button will light up when Input 5 has been selected into Dynamic1.
Is VMPB using this already ? I guess not, right ?
raugert
#574 Posted : Saturday, December 12, 2020 4:10:52 AM(UTC)
raugert
Canada
salut Guillaume,
Thanks for the report on the Dynamic inputs. I included the new commands because I saw they were added in the latest vMix shortcuts. I figured some users might want to test them. To be honest, at the time, I didn't completely understand how they work...
The Panel Builder has always had the ability to "dynamically" change inputs, commands and values within buttons by using the "grouping" method, but the button 'controlling' the change did not tally. I'm assuming that's what this activator for dynamic inputs will provide ? Hopefully, this information is also available in the API XML as Panel Builder doesn't use activators as such..
I still need to dive deeper into the vMix Dynamic inputs in order to get a better grasp on the concept, and how to apply it Panel Builder... I'm still not 100% clear.
Always a pleasure to hear from you.
porte-toi bien,
Richard
#575 Posted : Saturday, December 12, 2020 4:33:06 AM(UTC)
Richard
thanks for the quick answer.
At the moment there is still a bug in the API for DynamicInputs, so let's wait for the next update!
Maybe we can have another chat someday so that I can share ideas with you about DynStuff and how it will change completely how we can use and design VMPB for so many use cases.
I started to use them with my Akai controller, it's very promising !
Regarding activators, if you don't use them in VMPB, unfortunately Martin decided not to expose DynamicInputs and Values in the XML so this will certianly be a problem to reflect current status.
Let's talk about this when the bug is solved if you please !
Bien à toi !
Guillaume
#576 Posted : Tuesday, December 22, 2020 1:54:12 AM(UTC)
Hi Richard !
don't know if you get my email so I post here.
With v24 new release today, it seems you will need to work a bit for Panel Builder and the Dynamic Inputs and Values implementation.
I gave this a try in VMPB, here's what I noticed.
- Martin corrected the bug which prevented to use Dynamic Inputs this way
Function=Fade&Input=Dynamic1
This now works fine with VMPB
- The SetDynamicInput1-4 command can now use the Input field (rather than the Value field). This is now broken in VMPB.
- The SetDynamicInput1-4 and SetDynamicValue1-4 commands now update the XML status like this:
<dynamic>
<input1/>2</input2>
<input2>5</input2>
<input3/>
<input4/>
<value1/>
<value2/>
<value3/>
<value4/>
</dynamic>
Obviously VMPB needs to do it too. As is, it doesn't (and it breaks it when DynInputs are defined via vMix directly)
I believe this is a great news as I will allow VMPB to reflect/tally which inputs and values are used.
Bien à toi
Guillaume
raugert
#577 Posted : Tuesday, December 22, 2020 4:27:13 AM(UTC)
raugert
Canada
Merci Guillaume.
This is good news. I will be back home tomorrow and will have a look at this...
Richard
Joeboe
#578 Posted : Wednesday, December 23, 2020 2:44:23 AM(UTC)
Joeboe
Hi, I just realised I have a slight issue with the new Panel Builder release ....I set it to open last preset, which it does, but then goes blank after about 5 secs.....and I have to reopen the preset.....never noticed that before, but was using and updating a few icons when I noticed it.....what can be causing this.....
Thanks,
Joeboe
raugert
#579 Posted: : Wednesday, December 23, 2020 2:49:14 AM(UTC)
raugert
Canada
Hi Joeboe,
Thanks for the report. Yes, it appears that I broke this on the last update. :(
I'll fix it in the next release.
cheers,
Richard
Joeboe
#580 Posted : Wednesday, December 23, 2020 3:28:46 AM(UTC)
Joeboe
Thanks very much....you know how I love this app.....have many layout presets, with different key designs.....
Thanks again
Joeboe.
Guest (15)
