NDI
green output
Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Both copies of my Vmix upgraded to the latest and now i am getting audio but no picture on the output for the ndi capture but a solid green what is going on
Works perfect here. Check your settings
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
I had a similar issue after upgrading one of my vMIx computers, where it was not recognizing the NDI licence from my PTZOptics cameras. Not quite the same issue you are having but still related to NDI...
My solution: I uninstalled the Newtek 3.5 drivers and installed the new Newtek 3.8 drivers. It seems to have solved it.
Originally Posted by: DWAM  Works perfect here. Check your settings I am also having the same problem of getting solid green output after updating my VMix, which settings are you talking about. ?
Originally Posted by: wtmuradiotv  Both copies of my Vmix upgraded to the latest and now i am getting audio but no picture on the output for the ndi capture but a solid green what is going on I have the same issue. Please someone suggest me.
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
Green output is the result of using an unauthorised copy of vMix. If you are sure this is not the case please email info@vmix.com.au with your registration key.
Joined: 10/18/2015(UTC) Views messages in topic : 185 Location: Newcastle NSW Australia
Had it tonight. Easy fix. Uninstall and reinstall.
"Have you tried turning it off and turning it back on?"
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: av_dreamy  Had it tonight. Easy fix. Uninstall and reinstall.
"Have you tried turning it off and turning it back on?" Hi, this issue is happening to me right now. vMix HD license, currently on 23.0.0.66 version. First time that it happened to me and is persistent with the the green "opaque" output on Zoom meeting. It works okay for maybe 5-10 seconds but then the green layer comes in. I can still see the video but there's just this green layer on top (the fullscreen) of the video. Did you just reinstall vmix? or had to do any fresh install of Win10? Thanks,
NDI
green output
