wtmuradiotv
#1 Posted : Tuesday, January 1, 2019 7:33:42 AM(UTC)
wtmuradiotv
Both copies of my Vmix upgraded to the latest and now i am getting audio but no picture on the output for the ndi capture but a solid green what is going on
#2 Posted : Tuesday, January 1, 2019 8:21:31 AM(UTC)
Works perfect here. Check your settings
raugert
#3 Posted : Tuesday, January 1, 2019 3:38:57 PM(UTC)
raugert
Canada
Was thanked: 322 time(s) in 184 post(s)
I had a similar issue after upgrading one of my vMIx computers, where it was not recognizing the NDI licence from my PTZOptics cameras. Not quite the same issue you are having but still related to NDI...
My solution: I uninstalled the Newtek 3.5 drivers and installed the new Newtek 3.8 drivers. It seems to have solved it.
AccessNews
#4 Posted : Monday, May 27, 2019 5:23:06 AM(UTC)
AccessNews
Botswana
I am also having the same problem of getting solid green output after updating my VMix, which settings are you talking about. ?
yehtutbo
#5 Posted : Thursday, October 24, 2019 7:57:11 PM(UTC)
yehtutbo
Myanmar (Burma)
I have the same issue. Please someone suggest me.
#6 Posted : Thursday, October 24, 2019 8:53:50 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Green output is the result of using an unauthorised copy of vMix. If you are sure this is not the case
please email info@vmix.com.au with your registration key.
mashynewie2
#7 Posted : Saturday, October 26, 2019 6:49:23 PM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
Naughty Naughty
av_dreamy
#8 Posted : Wednesday, December 2, 2020 11:48:13 AM(UTC)
av_dreamy
Had it tonight. Easy fix. Uninstall and reinstall.
"Have you tried turning it off and turning it back on?"
seomaii
#9 Posted : Saturday, December 26, 2020 7:47:00 PM(UTC)
seomaii
Hi, this issue is happening to me right now. vMix HD license, currently on 23.0.0.66 version. First time that it happened to me and is persistent with the the green "opaque" output on Zoom meeting.
It works okay for maybe 5-10 seconds but then the green layer comes in. I can still see the video but there's just this green layer on top (the fullscreen) of the video.
Did you just reinstall vmix? or had to do any fresh install of Win10?
Thanks,
