3 Pages<123>
Lzrd
#21 Posted : Sunday, October 6, 2013 3:12:25 AM(UTC)
Lzrd
GREAT!
Just small wish to add minutes not hours counter to timmer: MMM;ss ex. 70:00, not 1:10:00.
#22 Posted : Wednesday, October 9, 2013 4:56:54 AM(UTC)
Was thanked: 4749 time(s) in 1632 post(s)
The countdown in vMix can do this, select MM:SS as the format and it will combine the hours into the minutes.
DAF
#23 Posted : Friday, October 11, 2013 4:47:03 AM(UTC)
DAF
Martin could you give me a suggest if we try to make some Rolling text from buttom to up could you give us a template like your tickers before, we need it for some crew credit tittle or something else....
best regsrds
DAF
broadcast101
#24 Posted : Friday, October 18, 2013 10:44:19 PM(UTC)
broadcast101
Hello all thanks for the project, but you can add an option for swf or animated text and image or PSD thank you.
thanks 2 users thanked broadcast101 for this useful post.
Adriankey4 on 10/18/2013(UTC), madness on 10/29/2013(UTC)
tubbis_2
#25 Posted : Friday, November 22, 2013 8:45:35 AM(UTC)
tubbis_2
Hello all!
Just discovered this piece of software and liking it.
I have one issue with the title designer and that is if it's possible to change images the way we can change text? It does look like it's doable but I cant figure out why I'm not having any success with it.
instudiomedia
#26 Posted : Monday, December 2, 2013 7:48:54 AM(UTC)
instudiomedia
Martin can you implement scrolling text function in Title Designer.It will usefull for scrolling text credits at the end of a show or in other situation.Thanks
Damn2Good4U
#27 Posted : Monday, December 2, 2013 10:14:01 PM(UTC)
Damn2Good4U
+1 for end credit....
I usually go to sony vegas or adobe premiere to do that..but if this can be added it be so nice
watchfulone
#28 Posted : Tuesday, December 3, 2013 12:46:43 PM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
We need some new features for the Title Designer, I am putting some ideas together.
Adriankey4
#29 Posted : Thursday, December 5, 2013 2:34:24 PM(UTC)
Adriankey4
Jamaica
What about adding after effects, premiere pro files with alpha and video formats like mp4 and quicktime video format both with alpha channel in thee title editor and maybe can add audio to the lower thirds.
Just ideas!!!!
AdrianJ,
Ja.
g-mo
#30 Posted : Friday, December 6, 2013 9:00:34 AM(UTC)
g-mo
I had quite the time with this feature using it wirelessly. It would work flawlessly for 30 minutes or so and then would lose connectivity. It could only be resolved with a reset of the software. Ultimately I ended up hardwiring through a switch and only had one more drop. This feature is a definite must have for the race coverage that we provide. I hope all the bugs can be worked out soon.
PeterWastson
#31 Posted : Saturday, December 21, 2013 8:26:59 AM(UTC)
PeterWastson
Great tool, very useful!
tobisw
#32 Posted : Tuesday, January 14, 2014 4:08:52 PM(UTC)
tobisw
Hello from Germany,
first of all, i would like to say Thank You for this great Programm.
I use Vmix for streaming our Icehockey Home Games. I would like to know, if it´s possible to generate also
a own scoreboard with the titel designer? Maybe, a tutorial exists for such kind of Question?
Regards from Germany
Tobias
#33 Posted : Wednesday, January 15, 2014 4:28:00 PM(UTC)
Yes you can design your own but there is no tutorial as far as I know, so you are best to play around with it a bit to get familiar with it.
You might get some help or ideas by looking through these threads:
http://forums.vmix.com.au/default.aspx?g=posts&t=1620
http://forums.vmix.com.au/default.aspx?g=posts&t=1254
http://forums.vmix.com.au/default.aspx?g=posts&t=1170
jip
#34 Posted : Sunday, February 9, 2014 6:54:32 PM(UTC)
jip
Estonia
the Title Designer is very nice. However, I have encountered an annoying problem when fine-tuning the title. If the xaml title is open in vMix, it cannot be edited in the designer and saved. You have to first close it in vMix and then save it, and after reload it again. I guess there are some file locking happening.
It would speed up tuning the titles a lot if the xaml could be saved without having to close the title in vMix.
Also, it would be really nice if a list of titles could be saved into a text file, because reloading xaml loses all title text presets every time - also when closing an opening vMix.
cambysys
#35 Posted : Thursday, February 13, 2014 10:07:57 PM(UTC)
cambysys
A couple of bugs.
Some observations:
1
White text is hard to see against the checkerboard background.
2
The text box drag handles are not obvious and hard to grab.
3
No grab to stretch horizontally when right justified.
4
If one sets the Text/alignment to Right then the cursor position gets mucked up.
To edit right justified text, Set to left justify. Click outside the text box. Then Click back inside it.
I added some pictures to the original blog post to show the result and the issues.
http://thomsoneu.blogspo...ownstream-key-issue.html
brian078
#36 Posted : Thursday, March 13, 2014 6:47:59 PM(UTC)
brian078
Please add the LineHeight property.
madness
#37 Posted : Wednesday, March 19, 2014 7:12:44 PM(UTC)
madness
It would be great to be able to include actual video footage in the title design IMO. I currently need to create dynamic title bars as an AVI file in my video editor, and then I need to create a title in editor without the bar, and then use 2 overlays. Perhaps the ability to mask the video for the title as well???
coskel22
#38 Posted : Saturday, April 12, 2014 2:50:58 PM(UTC)
coskel22
I have a question about saving the file and using the text editor available live.
I created my template, used SaveAs in the Editor, and then using admin permissions (Win 7) saved the xaml file and the PNG graphic to the "titles" folder in vMix.
They do not show up when I try to choose them using the Titles tab - but if I manually search for the template image, I can load it as an image.
What step did I miss when creating the custom Lower third?
Using vMix 12.0.0.124 x64 on Win 7, and my vers is the SD licensed.
Thanks in advance
Kel
Charssay
#39 Posted : Saturday, April 12, 2014 4:33:26 PM(UTC)
Charssay
You are not obligate to save them in the Vmix default folder for Title
You can create a folder where you put all your creation and open them doing ADD INPUT, choosing XAML and browse to look and choose your XAML
Rgds
C.
Thanks in advance
Kel
richardgatarski
#40 Posted : Saturday, May 10, 2014 11:02:27 AM(UTC)
richardgatarski
I'm joining all the positive commenters - the Title Designer is really useful! And I think it's OK that it has limited functionality (better that StudioCoast focuses its Resources for vMix).
One thing that bogged me quite a while turned out to be a Windows 8 issue (thanks Microsoft ;). In Win8 the windows scaling/resolution/adjustment - I don't what, displays only a part of the graphics loaded into the Title Designer. Don't know if this is related to Title Designer, or if I should change yet Another setting in Windows 8. Finally I got it working simply by running Win7.
And, as "watchfulone" already pointed out, Title Designer (and vMix) "need to be more compatible with other font types". Many of the fonts I have installed (eg True types) can not be used.
Thanks!
Similar Topics
About vMix Title Designer (Feature Requests)
by 540144407 5/14/2017 2:50:19 AM(UTC)
Roboto Font in Vmix Title designer (General Discussion)
by mburel1980 8/19/2016 2:17:33 PM(UTC)
VMix Title Designer not working (General Discussion)
by waynew 12/6/2014 1:04:29 PM(UTC)
vMix Title Designer Upgrades (Feature Requests)
by watchfulone 9/8/2013 8:13:24 PM(UTC)
vMix Title Designer - Coming Soon (General Discussion)
by admin 8/11/2011 2:10:04 AM(UTC)
3 Pages<123>
