51 Pages«<1213141516>»
Joeboe
#261 Posted : Wednesday, November 13, 2019 10:38:27 PM(UTC)
Joeboe
It is working great, except I thing I found an old bug that has returned....when I close Panel Builder and the popup window comes up, PB hangs, and I get an error message which says 'Panel Builder has stopped working,etc...' That was an old issue that went away, but now seems to return....I just click 'Cancel' and it closes..
chunnian
#262 Posted : Thursday, November 14, 2019 12:22:22 AM(UTC)
chunnian
China
Hello, blogger, I'm a novice. I don't have color change in the new version. I have color change in the old version. Is my setting right?
chunnian
#263 Posted : Thursday, November 14, 2019 12:34:38 AM(UTC)
chunnian
China
03.png (147kb) downloaded 7 time(s). 04.png (147kb) downloaded 4 time(s). 01.png (1,207kb) downloaded 3 time(s). 02.png (1,201kb) downloaded 4 time(s).
raugert
#264 Posted : Thursday, November 14, 2019 12:51:11 AM(UTC)
raugert
Canada
Was thanked: 322 time(s) in 184 post(s)
@chunnian
The new version will open up a floating "InfoBox". You can change the color of the button by clicking on the "Tally Icon" color box. It will open up a color picker, where you can select the color you like for the tally.
Note: the color of the button will not change if you haven't assigned a command to the button.
hope that helps.
kind regards,
Richard
chunnian
#265 Posted : Thursday, November 14, 2019 1:17:07 AM(UTC)
chunnian
China
@rauge
Sorry, I still don't understand. Can you give me a preset template for me to test?
thanks
chunnian
#266 Posted : Thursday, November 14, 2019 1:29:33 AM(UTC)
chunnian
China
@raugert
Maybe my expression is wrong, my English is not good.
I've tried what you said, but I can't,
When I create a coloerdbutton as a scoreboard, I click the button with the mouse and it doesn't change color.
Version 2.0.29 is OK.
chunnian
#267 Posted : Thursday, November 14, 2019 1:33:57 AM(UTC)
chunnian
China
@raugert
Can you add me wechat?
My wechat 13368082549
raugert
#268 Posted : Thursday, November 14, 2019 1:48:23 AM(UTC)
raugert
Canada
Sorry chunnian I'm not subscribed to wechat. You can email me at info@studio793.ca if you like to discuss offline of this forum.
Narcogen
#269 Posted : Friday, November 15, 2019 1:43:52 PM(UTC)
Narcogen
Will the iPad version update soon? I updated the desktop version and made some changes, and now the iPad app canot open the files. I've checked through TestFlight but there don't appear to be any newer versions.
Thanks!
raugert
#270 Posted : Friday, November 15, 2019 3:20:45 PM(UTC)
raugert
Canada
The new iPad version is now be availble for testing through TestFlight (Version 1.0.1 build 7)
Ronald555
#271 Posted: : Saturday, November 23, 2019 12:09:02 AM(UTC)
Ronald555
A hint for virtual PTZ users:
If you give the virtual PTZ inputs in vMix a name with a number in it like 'CAM 1 Preset A' then panel builder wil brighten up (tallied) also the CAM 1 source program/preview button instead of only the respective virtual PTZ input number.
Now you can see in the blink of an eye that CAM 1 is still in the program and you shouldn't change the position of it, this is very handy, thanks!
I use a 2nd Program button as a 'CAM 1 On Air' tally light next to my row of CAM 1 virtual preset buttons.
(this only works if the preview and program buttons are set to input numbers instead of input names)
(Unfortunately this doesn't work anymore in version 4)
raugert
#272 Posted : Thursday, November 28, 2019 5:02:01 AM(UTC)
raugert
Canada
New updated version 3.0.16:
https://cli.re/vMix-Panel-Builder-3.0.16
- added auto-hilite to colored Buttons when pressed
- added check for missing userIcons upon loading file
- added ‘default' button size in preferences
- added ‘default' button text size in preferences
- added 'close window' button on InfoBox
- fixed occasional VU’s flashing (windows version)
- fixed some font alignment issues (windows version)
- added Tally Icons to IconButtons
* You can now use separate icons for tallies.
Click on the small “Tally Icon” box to highlight it in “red” then select the icon you like.
Change the border size to “0”.
If the selected icon is a .png file, you can deselect the “opaque” button, and the button will take the shape of the icon along with it’s transparency.
If you leave the “opaque” button selected, the selected "Tally colour" will also be used, and will show through the transparencies of the icon.
Richard
thanks 3 users thanked raugert for this useful post.
Ronald555 on 11/28/2019(UTC), Joeboe on 11/28/2019(UTC), JW on 12/10/2019(UTC)
Joeboe
#273 Posted : Thursday, November 28, 2019 2:03:11 PM(UTC)
Joeboe
Love this improvement....it is great...now I can place that Tally Icon in a place where I can see it all the time...I placed them next to the 'Zoom' button, so i can see whan I am recording, streaming etc.....no need to look at the buttons...wish you could make them to flash, especially the Record' icon...you know I like to challenge you....can you make your buttons flourescent... I found a way to make the Tally Icons glow a bit..I used Photoshop and added glow....so, I used the words 'REC and STREAM' using the glow effect instead of the actual Icons...looks GREAT...so now when I am streaming, the word 'Stream' is showing in red with a glow ...same thing for Record..
Ronald555
#274 Posted : Tuesday, December 17, 2019 12:55:45 AM(UTC)
Ronald555
I found a little bug.
The editing info box is hidden when Panel Builder is set as always on top.
When using 2 monitors sometimes the box is completely disappeared.
Joeboe
#275 Posted : Tuesday, December 17, 2019 5:14:52 AM(UTC)
Joeboe
I found the same thing happens to me, but I just try not to let it bother me, but sometimes it can be a pain in the place where the sun does not shine......and another time, it jumps from at the side or where ever I place it, and comes directly infront of everything, and I have to move it again....this happens mostly when I go to change the size of the UI
raugert
#276 Posted : Tuesday, December 17, 2019 7:47:21 AM(UTC)
raugert
Canada
@Ronald555
I wasn't able to duplicate the info box disappearing (even with 2 monitors). Is it possible that you are running another program that is set to be on top of applications ? There could be a conflict in that situation..
@ Joeboe
In the next update, I'll make it so that the info box remains in place when changing the UI size.
cheers,
Richard
Ronald555
#277 Posted : Tuesday, December 17, 2019 8:00:35 AM(UTC)
Ronald555
I run everything on the same computer.
Panel Builder runs on the second (touch) monitor.
It is on top of the vMix Fullscreen and resized to 3/4 of the screen.
The other 1/4 of the screen is filled with 3 PTZ camera live feeds (multiview).
I found two other small issues:
After editing some things the tallies are sometimes not working, a restart does the trick.
Sometimes when I start Panel Builder before vMix it doesn't connect.
Immediately after moving the fade slider it connects.
Joeboe
#278 Posted : Tuesday, December 17, 2019 10:24:34 AM(UTC)
Joeboe
[quote
This was happening for quite some time...but I see it as not really a bug, so I launch vMix and then Panel Builder....but I found another bug....when I launch Panel Builder, all the icon buttons do not work except I edit one button, and then all buttons are populated, and work correct....I found this a few days ago....I have vMix to auto launch when windows launch, along with Panel builder, but I set Panel Builder to have a 45 sec. delay....
Ronald555
#279 Posted : Tuesday, December 17, 2019 9:13:16 PM(UTC)
Ronald555
I have a feature request.
See image, I like the white borders, I did it with 'labels' (opaque unchecked).
The problem is that the buttons are not working anymore, because they are on the background of the label.
Is it possible to add a 'create border' option or a 'label on background' option?
raugert
#280 Posted : Tuesday, December 17, 2019 11:25:16 PM(UTC)
raugert
Canada
If you Right-Click on the label and "send it to back", it will be placed behind the buttons and the buttons should function normally.
thanks 1 user thanked raugert for this useful post.
Ronald555 on 12/17/2019(UTC)
