Good evening, in the scripting function you want to run http strings to command other objects on the internal network, can I do it? thank you I await answers greetings Hector
Joined: 12/27/2012(UTC) Posts: 5,470  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
do I have to enter this string? http: // admin: admin@192.168.200.119/cgi-bin etc. etc. how can I do?
Quote:do I have to enter this string? http: // admin: admin@192.168.200.119/cgi-bin etc. etc. how can I do? Maybe explain what you want to achieve also google: vb.net httprequest and/or webrequest
I would like to run this script to send commands to devices outside vmix
to turn your coffee maker on (i'm guessing) Quote: Code:Dim request As WebRequest = WebRequest.Create("http://x.x.x.x:xxxx/brewcoffee")
Dim response As HttpWebResponse = request.GetResponse()
Console.WriteLine((CType(response, HttpWebResponse)).StatusDescription)
response.Close()
as mentioned before: google: vb.net httprequest and/or webrequest there are plenty of examples to be found
