fgolman
#1 Posted : Tuesday, December 9, 2025 9:44:21 AM(UTC)
fgolman
I'm floundering around with the VB.net scripting required for a POST WebRequest (GET was easy as it is the default).
Can anyone put some sample code out here to grab?
Here was my script with the GET code (this is to cause another program to load an XML configuration file):
Code:
dim intname as string = "testfile"
dim remotesystem as string = "http://127.0.0.1:9000"
dim remotecommand as string = "/api/state/load/" & intname & ".xml"
dim url as string = remotesystem & remotecommand
Dim myWebRequest As WebRequest = WebRequest.Create(url)
Dim myWebResponse As WebResponse = myWebRequest.GetResponse()
As noted above, now I need to use the POST method going forward. Same data although the URL has a slightly different format for the new API:
http://localhost:8080/api/v2/show/scenes/load?name=Example
Thank you!
Fritz Golman
RadioDNA
