Vi
Riculus
#1 Posted : Tuesday, October 15, 2013 7:19:44 PM(UTC)
Riculus
Hi All,
My church is currently streaming our service online with one camera and is ready to upgrade to multi cameras. This is our current setup.
1 Sony HD camera
Mac book pro
BlackMagic ultra studio mini recorder.
For what we are doing now this setup is great.
This is what we hope to accomplish:
Use Vmix software
Add 2-3 more HD cameras
live video feed to a projector
This is what we have:
HP desktop with 2.4 GHz, 1TB HD, 4 GB ram
This is what we need:
Video capture card to support at least 4 outputs
Best HD/SDI camera
Adapters/ wiring...etc.
Please let me know what you recommend. We are trying to get this done soon.
Thanks,
Riculus
fordry
#2 Posted : Tuesday, October 15, 2013 8:54:18 PM(UTC)
fordry
Well, you would need to get a Blackmagic Decklink Quad for you inputs.
Potentially will need to use some form of HDMI extender or SDI cameras.
With SDI cameras you will spend a bunch and unless you really have a pro team and setup I'm just not entirely sure its worth it. A nice $1000US HDMI camera will be just about as good, especially for streaming purposes, and if you are getting several then that is a huge savings even with adapters to extend the HDMI signal. Blackmagic sells HDMI to SDI adapters for about $500 a piece but at around $1500 combined for camera and adapter thats still around $2000 less than the cheapest SDI cameras you will find. Money best spent elsewhere if you want my opinion.
One thing to think about is if you ever want to put the live video feed on a projector screen in the sanctuary/room/whatever that running the video through vmix on a computer is probably going to introduce more delay than you will get going through a standalone video mixer. I'm not trying to knock vmix, I think its great, but that is a limitation you need to consider.
Also, that computer of yours, if its not a quad core with a standalone video card, I'm not sure i'd recommend it. The ram is fine and the hard drive is fine and the speed of the cpu is fine as long as its a quad. Vmix depends on gpu capabilities a fair amount which is why it can perform so well. It doesn't need an extreme top end graphics card but its good to have a decent one. Streaming takes a fair amount of CPU resources which is why I recommend a quad, its just good to have plenty of cores to throw at everything.
Riculus
#3 Posted : Tuesday, October 15, 2013 10:08:04 PM(UTC)
Riculus
Fordry,
Thanks for you input.
We can upgrade the PC if that becomes necessary.
Is there anything I can do to avoid the delay. If not i will just resist going with the live feed to the sanctuary.
You recommend Blackmagic Decklink Quad, can you tell me why that card and what adapter i need for it.
What camera and adapter you recommend.
We also have a Mac Pro but Vmix is only PC. With the same info what you recommend that will give me the same results with Mac. Will the ATEM be my other option.
fordry
#4 Posted : Tuesday, October 15, 2013 10:43:32 PM(UTC)
fordry
Well, per the documentation, vmix adds about 2 frames of delay all by itself. If you are running at 50/60i/p that is 1/30th or 1/25th of a second. Add in any delay that the ingest card adds, which may be a frame or 2 itself, and you could be looking at a pretty noticeable delay. If you are using a slower frame rate, say 25 or 30, it will be extremely noticeable. If that is something that is important to you, you may want to look at a standalone mixer such as a Blackmagic ATEM. My church is using 2 ATEM TV Studios, 1 for video mixing and one for handling the projectors, and then using vmix for video streaming and recording to hard drive/dvd. The delay introduced by running the video feed from Camera to video switching ATEM to projector control ATEM to Projector is very minimal and you have to watch for it to really notice it.
I have never actually seen or used a decklink quad but as far as i know, you just install it, install the drivers, and off it goes. you get 4 inputs that you can use in vmix. The cheaper alternative is as many decklink minis as inputs you need but you need a system with that many pci express slots and while I assume they should all play nice together, I don't know that they would for sure.
Cameras, if it were me, I would get Canon Vixia HF G20's, run the HDMI into Blackmagic HDMI to SDI converters, run that into your mixer. The G20's can be found for around $1000US (if you are in another country than I am not sure what is available and pricing and you would want to talk to someone who knows more about that region) and are very good cameras.
As for running vmix on your mac, if its an Intel based Mac I would just use Bootcamp and use Windows to run vmix. There isn't another option for vmix.
Similar Topics
vMix used in a 4D video playback (Showcase)
by Egriswold 8/14/2026 4:48:00 AM(UTC)
Improve the MultiView (Feature Requests)
by LewisMcParlane 8/13/2026 5:30:03 PM(UTC)
I need a VMIX pro to help me via ZOOM (General Discussion)
by curiousgeorge 8/13/2026 7:34:22 AM(UTC)
Linear Camera Zoom on Virtual Set (Feature Requests)
by Cyprian 7/21/2026 7:14:59 AM(UTC)
NDI and Video inputs blanking out. (General Discussion)
by boris9831 7/14/2026 7:37:23 AM(UTC)
Remote/API access to the Replay event preview loop (in/out range) (Feature Requests)
by kamaleaomedia 6/26/2026 8:06:57 PM(UTC)
audio issue and clicks when reading video file MP4 (General Discussion)
by papaG4 6/25/2026 4:54:22 AM(UTC)
MIDI Joystick sensitivity (General Discussion)
by DThompson55 6/23/2026 10:12:49 AM(UTC)
CueScope: Read-first MCP server for AI-assisted vMix workflow review (3rd Party Software and Development)
by Video-Chopper 6/19/2026 7:41:02 AM(UTC)
new PTZ provider option (3rd Party Software and Development)
by mavik 6/5/2026 10:17:59 PM(UTC)
vMix Call — group audio level via API? (vMix Call)
by Mathias Schneider 6/4/2026 10:46:24 PM(UTC)
Excessive Source Drops, Render Drops, and Sync Issues with PTZOptics Studio 4K via NDI in vMix 29 (NDI)
by Matts887 6/2/2026 10:38:07 AM(UTC)
ARM for Windows is Getting Interesting - Nvidia RTX Spark (General Discussion)
by Anders 6/1/2026 6:55:33 PM(UTC)
Extended Audio Mixer View when Unpinned (Feature Requests)
by Anders 5/12/2026 5:24:54 AM(UTC)
More multiviews! (Feature Requests)
by TStevens92 5/11/2026 9:46:40 AM(UTC)
Problem with video "yellow vertical line" (General Discussion)
by autarh 5/11/2026 8:02:05 AM(UTC)
Individual SRT Status (Feature Requests)
by alias 5/6/2026 2:18:12 AM(UTC)
OMT Viewer (OMT - Open Media Transport)
by kaduramos 5/5/2026 1:31:25 AM(UTC)
VLC Video Program Selections? (General Discussion)
by knbPixels 5/1/2026 12:54:36 AM(UTC)
ASIO Audio devices not working in vMix - a warning (General Discussion)
by Roy Sinclair 4/30/2026 8:33:13 AM(UTC)
Request: API Total Time Remaining in VideoList (Feature Requests)
by ChrisHoS 4/25/2026 5:01:15 AM(UTC)
Using Davinci Replay Surface with vMix Replay (Instant Replay)
by Adriankey4 4/23/2026 12:57:54 PM(UTC)
Change FPS and Resolution for SRT, While Leaving RTMP As Is? (General Discussion)
by JohnDoe415 4/20/2026 3:43:35 PM(UTC)
Streamdeck video thumbnail limit (Feature Requests)
by Josemite 4/2/2026 3:06:45 PM(UTC)
Tie saving of Zoom plugin info to the application, not the show file (Feature Requests)
by knbPixels 3/21/2026 6:25:38 AM(UTC)
[FREE] VRC (Video Recording Control) (3rd Party Software and Development)
by Kotin 3/21/2026 4:09:54 AM(UTC)
Meet AK GO – The Advanced Software Controller that turns vMix into a High-End Vision Mixer (3rd Party Software and Development)
by ali 3/15/2026 6:49:17 AM(UTC)
Possible to set new in and out on exesting replay event instad of moving? (Instant Replay)
by TL68 3/13/2026 5:41:55 PM(UTC)
vMix Zoom Plugin: Weird Audio Behaviour and Video Color/Dynamic Range (General Discussion)
by XenoJin 3/8/2026 4:13:34 AM(UTC)
What is "virtual inputs"? (General Discussion)
by TL68 3/6/2026 12:46:15 AM(UTC)
