audio issue and clicks when reading video file MP4
Joined: 11/12/2023(UTC) Posts: 2  Location: Paris Was thanked: 1 time(s) in 1 post(s)
Bonjour, I have audio clicks and cuts when I read video files. I use VMIX to project video files in our auditorium: I send output to FullScreen ( to the Epson videoprojector ) and have a MOTU audio interface for the sound system. Sound cut and clic as there are no problem reading the file un VLC ? I use VMIX 29.0.0.48 and Windows 11 updated... I use the MOTU audio wave 64bit and I try with the MOTU ASIO... but problem is the same.
It's very annoying for the audience!
any idea ?
Ronan
from Paris France !
Originally Posted by: papaG4  Bonjour, I have audio clicks and cuts when I read video files. I use VMIX to project video files in our auditorium: I send output to FullScreen ( to the Epson videoprojector ) and have a MOTU audio interface for the sound system. Sound cut and clic as there are no problem reading the file un VLC ? I use VMIX 29.0.0.48 and Windows 11 updated... I use the MOTU audio wave 64bit and I try with the MOTU ASIO... but problem is the same.
any idea ?
Ronan
from Paris France ! check if the audio of the files or the playback have a DC offset (this was the case with some of my recordings from a particular camera) if that is the case you can use a VST plugin to rectify that
Bon, I use this PC with Protools too and I change the "samples per buffer" ! (512 to 128) for audio recording.
I set back the "Samples per Buffer" to 512 and it's OK .
For audio 128 samples at 48k is 3ms : good for audio recording 512 samples at 48k is 11ms : good for VMIX as render time in my case is 5ms to 12ms...
Ronan
PS: these are movies so I didn't check offset DC. I just ajust FPS from 24 to 25 (using Shutter Encoder) and it reduce the amount of GPU Mem from 59% to 44%. I have a RTX 2060.
 1 user thanked papaG4 for this useful post.
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 271 times Was thanked: 40 time(s) in 38 post(s)
Originally Posted by: papaG4  I just ajust FPS from 24 to 25 (using Shutter Encoder) and it reduce the amount of GPU Mem from 59% to 44%. I have a RTX 2060. Newer heard of this software before. Thanks for sharing.
